Running 4 bar map sensor, BUT, BIG but...
devonutopia
Devon, U.K
PD300 Skoda Fabia
This is a big but! In future I would NOT use bosch part number 0 281 002 316 http://rb-aa.bosch.com/boaasocs/index.jsp;jsessionid=9090D6556F63A10AF31888AFA73270C7.sundoro?ccat_id=110&prod_id=203
It turns out the reason for the implasuible correlation error was due to a voltage difference between how this sensor reads pressure through voltage and how the stock 3 bar sensor reads it. Not sure on the exact symptoms, but it needed a resistor incorporating into the wiring to take out half a volt to allow the sensor to work in my car.
One side effect now though is my mapping is now making more boost than it did before. Sometimes over 2.5 bar overboost and between 2.2 bar and 2 bar of sustained solid boost, compared to 1.8 before. Car does feel a bit faster though.
There HAS to be a 4 bar sensor out there which does not need this resistor work as both my tuner and the auto-spark doing the work had not seen this before and the tuner had mapped 4 bar setups before.
Is it possible that http://rb-aa.bosch.com/boaasocs/index.jsp;jsessionid=9090D6556F63A10AF31888AFA73270C7.sundoro?ccat_id=110&prod_id=203 is NOT the correct 4 bar sensor to use and there is a different model number which is more plug & play for these engines? :)
mojogoes
england
mk3 tdi golf
Hi Jason what was it that gave you reference to this 4bar sensor in the first place , and if it were someone on this forum had they actually used it on there setup themselves!!
Got Bearings?
SoCal
2001 Golf GLS
Is there a way your tuner can rescale the MAP table in your tune to correspond to this MAP sensor voltage?
vwmikel
Vendor , w/Business number
Las Vegas, NV
'94 Golf Sport TDI
I'm a little confused. The map sensor linearization in the software correlates pressure to voltage. If voltage is different then you should be able to just alter the voltage there (when you find these values and set them into a map the voltage will be in the axis description). If you have figures I could try to fix it for you....either that of there's something I'm missing here. :)
devonutopia
Devon, U.K
PD300 Skoda Fabia
Thing is, my mapper has mapped 4 bar sensors plenty of times and this voltage thing has never cropped up. It seems whatever sensor I used was probably not the right one. Someone here must have swapped 3 bar out for 4 bar, and been able to just "plug & play" so I am curious as to what part was actually used.
PS: I was told the part number I got by someone on here - don't recall who but I assumed it based on prior knowledge. Now I need to actually find someone who has done the conversion with no resistor needs, and it's worked right away. :)
hatemi
Finland
Audi A6 4F 3.0TDI
You propably wouldnt be able to run a 4bar sensor in place of 3bar without remap in the firstplace. My original 012k ecu was ok with 2.5bar->3bar but 012bd was in the limp mode at start most of the time. So either youre calibration is off or you got yourself a 12v sensor :D
mojogoes
england
mk3 tdi golf
All it needs Jason is rescaling with the matching voltage i know your tuner may have done 3bar to 4bar map sensor changes before but were they not with 1.8 20v motors i.e petrol motors and not diesel motors which he hasn't done before!!
20vK
London, UK
150PD Mk4 Golf
I've got the same sensor as jason (but haven't fitted it yet)
Reccomended by numerous people on this forum.
If it doesn't even plug in correctly without butchering the wiring, it seems a bit daft to fit it if I'm going to have issues (which I won't know until I've fitted it and got it at the tuners - too late by then)
If we know of a definate plug in sensor (no matter whether it needs re-mapping or not - which it will) then I'd rather spend another load of money and get a different one.
devonutopia
Devon, U.K
PD300 Skoda Fabia
I have a new map to upload from my mapper now which is supposed to work OK without the resistor in place. So I shall be experimenting one evening this week.
hatemi
Finland
Audi A6 4F 3.0TDI
That whole resistor thing sounds fishy... The whole point of getting a 4bar map is to get more headroom for boost that ecu sees and can react to. You can wire your 3bar sensor inline with a resistor and you end up with more boost and wrong info sent to the ecu. So if you put the resistor inline the sensor it will indeed just fool the ecu to see LESS preasure. And that will lead to a limp mode even more likely. What you need to do is calibrate the MAP sensor in the software so it sees the right preasure all the time. Simple mod if you know the voltages at different preasures from your new sensor. And find the damn spot in the code where the sensor linearisation is :D
I'm going to use VEMS 4bar sensor with my own car. Cheap and it even had the calibration voltages stated at their website. You will have to cut the wiring loom but thats a given since you will be hard pressed to find a sensor with same connector that the OEM sensor has. http://shop.vems.hu/catalog/product...d=121&osCsid=7d923a240158976da844f7ab7f6d6cc9
Youll need the 5v sensor.
devonutopia
Devon, U.K
PD300 Skoda Fabia
I really wanted to stick with Bosch. I shall get there in the end, but wondered what others had achieved successfully. :)
Rub87
Belgium
Ibiza '99 90HP
If you just go to a decent tuner there's no problem of making ANY linear 0-5v pressure sensor work with the ecu..
tell your pro-tuner to look in the hexdump in 16bit for the sequence 200; 3000..
StingrayRT
Slovakia
AUDI A6 2.7Tdi Avant Quattro
Never have any problems with 4 and 5 bar MAP just re-calibrate ECU for new MAP sensor and it works as hell!!
shadowmaker
Finland
2.5TDI
So there's a 5bar MAP available too. I might be needing one.
Rub87
Belgium
Ibiza '99 90HP
maybe 10 bar is more something for you., check on the link to the Bosch site :D
mojogoes
england
mk3 tdi golf
Shadow the best thing you could do with yours is just connect the map/maf sensor in free air no housing and just mount the sucker to the front of your Van JOB DONE!!...............lol;) :D .
Rub87
Belgium
Ibiza '99 90HP
I think he'll already have an airspeed indicator for when he's exeeding the measuring range of the oem tacho.. ^^
Rub87
Belgium
Ibiza '99 90HP
0 281 002 576, plactic connector housing 1 928 403 736.. ordered mine already :)
Rub87
Belgium
Ibiza '99 90HP
Hey devon, my 4 bar sensor is in, and it works perfectly ;) no errors etc.. Pressure in vag com also is able to show op to 4000mbar :D
It's only the linearisation, nothing else.. (to let it work without dtc)
devonutopia
Devon, U.K
PD300 Skoda Fabia
Which exact part number have you got please? :)
Rub87
Belgium
Ibiza '99 90HP
The one from post #22..
but the one you have should work just the same.. it's all in the tune..
devonutopia
Devon, U.K
PD300 Skoda Fabia
Looking at the specs of the 2 sensors, they do seem to be slightly different. If my new map doesn't work, I'm going to go and get this sensor instead. :)
fenwick458
England
'12 T5 Van
is this plug and play? or does it need some mapping...
also can you buy less than 100 contact pins!?
