Agree completely!
Please reintroduce this product!
Production has stopped (at least temporarily) but he does have some kits in stock. He was selling the kits with or without the filter. You are correct that you can choose any brand of filter you want, but it must have 8mm (3/8") hose connections and it must physically fit in the space to mount and have the correct diameter for his bracket. Any filter that meets these requirements will work. The filters he uses are (were) actually the stock fuel filters from a 1984-1989 VW Diesel engine (without the pre-heat port). This page lists MANY filters that should work: http://www.findpart.org/part/kol-50013181Was the production stopped? If so, why? I thought Andrew was selling brackets and hoses. You're free to choose any filter you like.
Don,Production has stopped (at least temporarily) but he does have some kits in stock. He was selling the kits with or without the filter. You are correct that you can choose any brand of filter you want, but it must have 8mm (3/8") hose connections and it must physically fit in the space to mount and have the correct diameter for his bracket. Any filter that meets these requirements will work. The filters he uses are (were) actually the stock fuel filters from a 1984-1989 VW Diesel engine (without the pre-heat port). This page lists MANY filters that should work: http://www.findpart.org/part/kol-50013181
Some of these filters are easier to find than others. The Mann and Bosch filters are still pretty easy to find in the US.
I cannot speak for 2micron, but if enough people PM him and tell him that they are aware of the possible limitations of this filter kit and want to buy it anyway - he might relent and sell the ones he has in stock. Whether or not he has any more manufactured will depend on whether or not he can come up with a better filter or a better idea. Only time will tell about this.
Have Fun!
Don
I got an email and PM today from 2micron today and he has a prototype for a new "Contain Flow" Return Filter design that can use either a one or two micron spin-on filter. He gave me permission to post info about his progress.
Here is a pic: (click on the pic for a bigger image)
The filters used are designed for service station fuel pumps. They are either:
Cim Tek 70025 1 micron Microglass filter
Or
Cim Tek 70057 2 micron Microglass filter
These filters are available from a variety of sources for under $25.00
Andrew has been flow testing these filters for the last week and their flow rates and pressure ratings far exceed our needs. Also the new filters are spin-on, so the bracket will not have to be loosened from the stock fuel filter to replace the return filter. It looks like a pretty good solution for those who thought the original 5 micron filters were not good enough. I do not know when he will have this new design ready to sell/ship but he will post in his vendor thread when they are available for sale.
Have Fun!
Don
You are the first person I am aware of to report having an HPFP failure with some sort of return fuel filtration in place. I am sure Andrew (2micron) would be very interested in getting details of your set up and experience.I wouldn't worry too much about the micron rating of the filter. I had a $2 metal can disposable filter in the same place as this one we are discussing here. I also had a $2 clear plastic filter inline with the return line back to the tank. After the HPFP failed the metal can filter was heavy and full of very fine "dust". It's my belief that these filters saved VW from replacing the majority of the fuel system. They only replaced the HPFP.
LOLIf Andrew will also manufacture a Bobblehead of himself, I'll replace the Saint Christopher figurine on my dashboard with it!
How about something more like this for a clogging indicator. I you get one with the correct color range, you won't have to remember what pressure to change the element.Here's another shot of the bracket. Andrew is working on a gauge to help show if there is a pressure change that would help indicate time for a filter change. The filter is readily available and cost is about $23, here's a link.
Unfortunately, this would only be partially successful. Many (most?) of the metal bits are aluminum and they would happily pass right past the magnet and do nothing (except cause damage downstream).Wonder if a magnetic metal detecting switch could be installed. After x amount of metal is detached the switch would turn on and that could be run to an idiot light.
Andrew has a 2 micron filter pre-stock filter.....this version is to save the rest of the fuel system from collateral damage of the HPFP failure....Why not make the 2 micron fuel filter kit a pre-filter instead of a post pump filter? I know the initial purpose was to prevent shavings from being returned to the fuel tank. However a quality 2 micron filter would provide for a improved filter rate on the first pass as well as during cold starts prior to thermo valve opening up.
The only problem with this approach is that we really do not have any reason to think that the HPFP failures are caused by dirty fuel. Most believe that the primary causes (aside from pump design) are poor fuel lubricity and/or water or gasoline contamination. None of these causes would be caught by even a 1 micron filter. Better filtration of all of the fuel going to the pump would not hurt, but it probably would not help very much either.My goal would be to prevents failure with cleaner fuel prior to the fuel pump.
No argument here. The only possible problem with finer filters is the possibility of them getting clogged. A finer filter will (or at least should) trap more stuff and therefore perhaps clog up faster. How often you would have to change the filter would change and without more knowledge of the particles (and how many) it would trap, I do not know how and how much it would effect filter change frequency. This is the one of the reasons why 2micron's return filter will probably have the gauge on it - to measure the pressure drop through the filter. Choice of filter (like most other choices) is based on a series of compromises. With filters it's filtration vs. life, with tires it's handling (traction) vs. treadwear, etc.I would agree- But would still prefer to have the cleanest fuel possible.
