Old May 25th, 2019, 05:21   #301
JETaah
Fuel Economy: 53 max, 42 min, average 46
Originally Posted by memphisride View Post
Hello, My 1999 1.9 TDI goes into limb mode when going up an incline at around 3000 RPM. I can also make it do it on the flat if I put the pedal to the floor. It will also idle rough when you are have the clutch in slowing down to stop. Once stopped, it goes back to a normal idle. I have replaced the wastegate valve, turbo boost solenoid and cleaned the mass air flow sensor. Any ideas would be appreciated.
Better to put this in the MK4 section but since you asked....
Diagnose it by reading the fault codes first. You may have replaced everything but the faulty parts.
I would look to see that the the turbo actuator moves freely. It is liable to be in a position where it is stuck or does not fully open.
The other problem is most likely related to too much fueling, A simple adjustment of the injection pump would be all it needs. (Hammer mod)
Both of these subjects will be covered in the list of How to section.
turbo repair -- if it is not the actuator alone jamming things up
http://forums.tdiclub.com/showthread.php?p=1340914
turbo actuator:
https://www.idparts.com/vane-actuato...alh-p-530.html
hammer mod -- you would need to have VCDS software to accurately adjust it. On older cars this might induce a fuel leak due to disturbing flattened gaskets. Have a gasket kit on hand.
http://forums.tdiclub.com/showthread.php?t=258297
gasket kit:
https://www.idparts.com/tdi-injectio...03-p-1143.html
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old May 26th, 2019, 11:45   #302
Petesaguytdi
Number 1 issue to check first is if you have the cloth weave vacuum hose in use, check at the Turbo vane actuator unit where the hose has a tight bend,
you may find that the hose looks fine but the rubber has dried and cracked at that bend creating a slow leak.
That will often give you a limp mode issue on long sustained boost situations like a long hill climb.
99.5 A4 Jetta, ~359,000km Ventectomy, neoprene swaybar bushings,Koni FSD's, Shine rear bar, a4 deluxe tb kit. dieselgeek skid plate,sigma 5 shifter, vag-com, Euro110hp version vnt15, pp520's, Aligator Kerma level 1, Tdi heater, vr6 clutch/g60 flywheel, CAT fuel filter
2004 Passat sedan, Malone stage 2, 2005 passat wagon 5spd DUK, 1756 Hybrid, Malone custom tune
Petesaguytdi is offline   Reply With Quote
Old June 5th, 2019, 14:27   #303
drjarvis
miss firing when driving 1.9 tdi
drjarvis is offline   Reply With Quote
Old June 9th, 2019, 07:08   #304
memphisride
TDI(s): 1.9 Beetle
Thank you for your reply. We are going to change all the vacuum lines next. There is only 158,000 KLMS on my bug. It has spent a fair time in storage.
memphisride is offline   Reply With Quote
Old June 9th, 2019, 07:13   #305
memphisride
TDI(s): 1.9 Beetle
turbo actuator:
gasket kit:
Thank you for your reply. We are going to change the vacuum lines next. I will post the results.
Where's all the threads LMJ Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 April 24th, 2013 19:59
Got some new threads... velociT General VW Discussion 5 August 8th, 2008 23:15
Want to get really old threads... BeetleGo TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 2 October 5th, 2006 06:02
All of the Epsilonian threads are gone! valois TDI Power Enhancements 1 November 3rd, 2000 00:15
Page generated in 0.17445 seconds with 11 queries
[Output: 74.34 Kb. compressed to 66.47 Kb. by saving 7.87 Kb. (10.59%)]
