Old October 13th, 2019, 09:15   #1
philll
TDI(s): passat
Default transmission
is it the transmission or torquer converter that goes bad. or does one go bad that make the other go bad . on the 05 Passat. and if you changed the trans fluid evert 40.000 could it last to 500.000. thanks
philll is offline   Reply With Quote
Old October 18th, 2019, 09:14   #2
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
ask and you will receive.
http://kansascitytdi.com/01v-zf5hp19-faq/
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old October 19th, 2019, 08:06   #3
Rimrack
Default Transmission problem 2000 jetta 1.9
Been neglecting VW diesel all
Summer and want to get it ready for winter use. Replaced both transaxles last year. When shifting into reverse car "bolts" rapidly. Have to hit N or i will run through the shop. Engine seems to be idling high. Read book and cant see how to reduce idle? Also when shifting into R it grinds a little... ????
Rimrack is offline   Reply With Quote
Old October 19th, 2019, 08:07   #4
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Post your own new thread. It's the right way to get the best amount of help.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
Old October 19th, 2019, 08:32   #5
GoFaster
Moderator at Large
No one can predict the future. Regular fluid changes should help, but there are no guarantees.
Huh? Your car only contains one "transaxle". (Do you perhaps mean "drive shafts?")
Sounds as if the torque converter lock-up clutch is remaining engaged. Why that would be the case ... requires the experts to diagnose. It could be internally binding, or it could be the control valve commanding it to remain locked when it shouldn't.
It would sure help to know exactly which make, model, and year that we are talking about here. But, assuming it is a VW TDI engine, the idling speed is electronically controlled and is not adjustable. What IS the idling speed?
Again, it would sure help to know exactly which make, model, and year. But this symptom is consistent with a torque converter lock-up clutch that is remaining engaged when it shouldn't.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old October 23rd, 2019, 06:33   #6
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
I agree with GoFaster, TCC is probably stuck on. Could be TCC solenoid stuck or the Valve stuck. Best course of action is to pull pan and inspect, break open the filter to look for signs of metal failure. If its clean replace the TCC solenoid and while the TCC solenoid is out stroke the TCC valve to make sure it isn't sticking.
What does "seems" mean. Either its idling high or its not. I think all these cars had a tach. Whats the idle at? Or is it that your car is "bolting" so you are assuming the idle is high?
This might be the TCC stuck on also. Sometimes when TCC is stuck on it Vibrates the car, and sometimes it makes the clutch chatter so bad it makes noise. But maybe you have a major failure too that is making noise. No way to know through a forum post.
Manual transmission, DSG transmission fluid change badnews Fuels & Lubricants 13 February 9th, 2018 04:42
01M transmission differential fluid level too high, leaking from transmission? alex_tdi VW MKIV-A4 TDIs (VE and PD) 4 January 28th, 2016 02:50
Transmission Fluid Change - Automatic vs Manual Transmission tca32123 TDI 101 11 May 20th, 2014 19:32
Low transmission fluid? Or bad transmission? sharpfin0 TDI 101 2 August 1st, 2013 08:46
Considering Royal Purple Automatic Transmission Fluid in the 01M Transmission... rezmarian VW MKIV-A4 TDIs (VE and PD) 5 July 28th, 2011 09:12
Page generated in 0.15595 seconds with 11 queries
[Output: 82.27 Kb. compressed to 72.60 Kb. by saving 9.67 Kb. (11.76%)]
