Old October 10th, 2019, 18:42   #1
Matthewsz
Default 2009 sportwagen alarm
Anybody knows why the remote or starting the car won't stop the alarm? I got the car recently and found some kind of aftermarket alarm box with wiring behind the knee panel, I removed all of that and I'm not sure if that's related to my problem. It shouldn't need an aftermarket junk for the remote to function properly. I have at least one bad door switch but for example today after driving I stopped the engine, pulled out the key and as soon as I opened the door the alarm went off?! Why is it even armed when driving? Remote didn't stop it, starting the engine again didn't stop it.
Matthewsz is offline   Reply With Quote
Old October 12th, 2019, 02:41   #2
STDOUBT
STDOUBT's Avatar
Best bet is to scan it for codes. VCDS will even tell you the part number that's malfunctioning if that's what's happening.
Find some good mechanics here:
http://forums.tdiclub.com/showthread.php?t=130044
2003 Jetta TDI 1.9L 5-speed
Malone Dynamic EGR ~ cooler delete ~ Euro pipe ~ ventectomy
Search Tip: search this site best by using Bing: tdiclub topic
STDOUBT is offline   Reply With Quote
Old October 12th, 2019, 02:51   #3
Matthewsz
I have vcds, but where does that tell me why I can't stop the alarm once it goes off for whatever reason? My 2006 and 2003 didn't have this problem.
Old October 12th, 2019, 23:01   #4
STDOUBT
STDOUBT's Avatar
Just run a full "Autoscan" and sift through the results. I'd wager there are some "intermittent" or "ground to earth" problems with some wiring harness or module someplace. you can search the codes on the ross-tech site and get a page with possible causes + solutions.
2009 SportWagen Overheat peterloron VW MKV-A5 Golf/Jettas 3 May 15th, 2014 13:05
Intermittent driver side seat belt alarm on 2009 Jetta Sportswagen durangotdi TDI 101 2 May 5th, 2014 17:56
2009 Jetta TDI: Intermittent alarm and door locking/unlocking. altern8energy VW MKV-A5 Golf/Jettas 5 December 10th, 2012 15:54
Traded my 2009 Sportwagen dave729 VW MKV-A5 Golf/Jettas 0 December 8th, 2012 19:33
My 2009 Sportwagen JSWTDI09 Jetta/Bora/Vento TDI Picture Gallery 7 November 18th, 2009 12:59
Page generated in 0.10343 seconds with 11 queries
[Output: 63.50 Kb. compressed to 56.88 Kb. by saving 6.62 Kb. (10.42%)]
