Old October 8th, 2019, 22:01   #1
Kenter
TDI(s): 1 MKIV Jetta
Default Brake light and abs light on
As the title says they are always on. I've disconnected the battery tonight to see what if anything that will do. The brakes are brand new. As in new rotors and pads all the way around. Does my radio not working have anything to do with it? Any info is much appreciated.
Kenter is offline   Reply With Quote
Old October 8th, 2019, 22:14   #2
Nero Morg
Nero Morg's Avatar
It'll help if you scan for codes. Something else to check is your brake fluid resivoir, see if the connector is connected, and the resivoir is at least to the min mark.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is online now   Reply With Quote
Old October 8th, 2019, 22:19   #3
Kenter
Brake res is good topped off and connected. No codes in conjunction with aforementioned warning lights. Now that I'm logged into Tapatalk I can upload these pics I took. Noticed while doing the brakes these butt connectors. Not installed by me I might add.
Sent from my ONEPLUS A6013 using Tapatalk
Old October 8th, 2019, 22:29   #4
Nero Morg
Nero Morg's Avatar
That particular wire is for the brake wear sensor. It'll be a light that's a circle with three lines on each side of it. The brake/abs light is something else. Are you able to check the ABS module for any codes?
Old October 9th, 2019, 05:13   #5
Tdijarhead
Your abs light and brake light are related to each other. Since you don’t have a code reader to point you in the right direction, your best bet at this point is to take those connectors apart and completely redo them. Obviously someone had issues here before. If that doesn’t solve the brake/abs light you’re going to have to get it scanned with vcds unless there is another obvious problem somewhere.
Two of those wires go to the brake wear sensor and two to the wheel speed sensor. You can tape the two wires to the brake pad sensor together to eliminate the wear indicator light on you dash. The wheel speed sensor wires need to be fixed properly.
Tdijarhead is online now   Reply With Quote
Old October 9th, 2019, 06:38   #6
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You can turn the brake warning off in the Instrument coding, no need for any rewiring of anything.
If the ABS light is on, there is either a DTC stored in the ABS module, or the ABS module is not communicating. Which is it?
oilhammer
www.cardocautomotive.com
2006 TDI Abs Light and brake light blinking, no spedometer. Jesus Is Lord VW MKV-A5 Golf/Jettas 3 October 10th, 2015 13:36
traction control light ABS light and parking brake light flashing? dmaxwayne VW MKIV-A4 TDIs (VE and PD) 6 November 20th, 2014 10:45
2001 tdi jetta with ABS light and flashing brake light 95gltd TDI 101 9 April 4th, 2013 07:14
Coincidence? Brake light switch replaced ABS warning light on next day m509272 TDI 101 1 August 19th, 2009 00:16
Flashing brake light, abs light, dead door locks Diesel Cat TDI 101 8 July 2nd, 2007 10:21
Page generated in 0.14915 seconds with 11 queries
[Output: 74.77 Kb. compressed to 65.38 Kb. by saving 9.39 Kb. (12.56%)]
