Old October 8th, 2019, 11:44   #1
unorganizedplan
Default local VW key service in Canada?
Hi -
The lonesome remote flip key that came with my 2003 car has seen better days. I need a second one as a spare anyway, so am looking to have a new remote flip key cut and programmed to the car. I don't have a spare right now, not even a valet key, not even a non-chip key.
I have come across Sidewinder Key already, and prices/services seem decent. Before I pull the trigger with them, I thought I would check for any local (Canadian) places that can cut/program a VW remote key.
I am in southern Alberta. Local is preferred, but I don't mind shipping (Canada) if needed. Failing this, I think I'll stick with Sidewinder for supply/cut and borrowing the programming cable.
Any recommendations from you all? If I can't find a place here in Canada, is Sidewinder the place to go?
TIA,
Jason
FOR SALE: 2012 JSW Highline TDI w/DSG
2003 Jetta TDI 5spd
I have Micro-Can VCDS
unorganizedplan is offline   Reply With Quote
Old October 8th, 2019, 12:48   #2
steve6
I know a couple places in Toronto..
But really call around to the lock smiths, you most likely have 1 or 2 that could help you out.
If you can find someone with vagcom and vag tacho to program it to the car you can also order blank off amazon/other fav site for cheaper and get someone to cut it.
Not to diminish tdiclub for everything wonderful it has, but finding a local vw group on facebook is great for this type of info, its much more localized info now. quick search shows me 'alberta mk4 Volkswagen tdi's' etc.. you don't need tdi specific for this though.
steve6 is offline   Reply With Quote
Old October 8th, 2019, 13:37   #3
unorganizedplan
thanks for the info. i know this is not a TDI specific issue, but figure i'd ask here first. i'll look at some local VW FB pages and see what I can come up with. I already called a couple locksmiths here in Calgary area . . . no luck yet.
2003 Jetta TDI 5spd
Old October 8th, 2019, 14:28   #4
jokila
jokila's Avatar
Fuel Economy: 52/45/40
$70-$78 for a complete key FOB. All you need to do is get it programmed for the immobilizer. The remote access part you can do on your own.
https://www.tunemyeuro.com/replaceme...beetle-immo-3/
If all you want is to update the buttons get one of these for $10.99
https://www.tunemyeuro.com/square-ke...-panic-for-vw/
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
40K service at my local dealer... Ctyankee VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 September 10th, 2013 16:45
Getting a key cut in Canada jettaboy General VW Discussion 3 March 18th, 2009 12:07
Local, NJ service mfox25 Eastern USA 6 March 27th, 2003 12:47
My local Bosch Service center contact info Drivbiwire VW MKIV-A4 TDIs (VE and PD) 26 July 11th, 2001 23:32
Page generated in 0.10155 seconds with 11 queries
[Output: 65.29 Kb. compressed to 58.58 Kb. by saving 6.71 Kb. (10.27%)]
