Old October 7th, 2019, 10:46   #1
TFS1
TDI(s): VWGolf
Default Loud click when clutch released
Hey all. I'm new to this forum so forgive me if this isn't the correct place to post. I recently purchased a Mk6 Golf in a private sale. Its been a bit of a cash cow as had to replace the timing belt and its getting a new clutch on Thursday this week. Anyway, last Thursday I started hearing a loud click when releasing the clutch pedal around 90% of the way. Its going in to the garage on Thursday and the mechanic said he'll diagnose it but that there's 18 separate parts that go in to a clutch pedal so it could be any one of those components. Has anyone else had this issue and what was it? The master cylinder was worked on a couple months ago, mechanic said at that time the stiff clutch had caused it to burst a seal. Could this be related? Any info that could help pinpoint it would be appreciated. Just to mention: If I put pressure to the right when I clutch, it doesn't click. (I'm UK so its a right hand drive).
TFS1 is offline   Reply With Quote
Old October 12th, 2019, 12:33   #2
TFS1
TDI(s): VWGolf
Had the car in the garage. Turns out when the master cylinder was worked on, a spring was put on the wrong way resulting in the click. No parts but plenty Labour cost. Had the clutch replaced, front suspension arms, fuel filter, new brake pads and two new tyres. Drives like a dream now.
Knocking sound when clutch released ramiles1 TDI 101 6 October 25th, 2014 08:49
Should IP make a loud click? I need HELP Funguy TDI 101 2 September 19th, 2010 19:21
Loud squealing sound when gas pedal is released Jon Fernandes VW MKIV-A4 TDIs (VE and PD) 15 April 11th, 2010 17:49
Hazard/Turn Signal Relay - Click, Click, Click ACHTUNG TDI VW MKIV-A4 TDIs (VE and PD) 1 March 26th, 2006 15:02
Signal light goes bananas..click click click click koni TDI 101 7 November 16th, 2004 19:44
Page generated in 0.12980 seconds with 11 queries
[Output: 52.07 Kb. compressed to 48.18 Kb. by saving 3.89 Kb. (7.47%)]
