Old October 7th, 2019, 06:14   #1
POWERSTROKE
POWERSTROKE's Avatar
TDI(s): 2002 Golf
Default Coolant Valve 16512 code
Scanned with vag. The code is coolant valve 16512 / n214
The symptoms are it takes a long time for the needle to get to 190 of ever depending how far we go. Is this a thermostat or coolant sensor? How do you change the thermostat?
It's kind of fun to do the impossible.-Walt Disney
POWERSTROKE is offline   Reply With Quote
Old October 7th, 2019, 07:31   #2
Dannyboy
Dannyboy's Avatar
Fuel Economy: All good on the motion lotion
Thermostat, temperature regulator as its sometimes called. Mk4s usually fail open and overcool
Dannyboy is offline   Reply With Quote
Old October 7th, 2019, 07:37   #3
eddieleephd
Fuel Economy: 38mix / 47@70-75
Yes, not reaching temp is due to thermostat. The code could be the temp sensor not reading properly.
If you have vagcom check both temp sensors to see if they match.
Never hurts to install a new thermostat either, however, if the temp sensor is the issue it won't fix the code.
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Bosio DLC 1020's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old October 7th, 2019, 10:44   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I never, ever, do the thermostat without replacing the sensor. The sensors are cheap, easy to swap, and fail often enough that it is not worth the hassle of guessing.
But you can watch the coolant temp data in both the Engine and the Instruments to compare both sides of the sensor, as it is unlikely they both fail together (but are both part of the same sensor, so...).
Really couldn't ask for an easier thermostat than the ALH. Get a new neck and o-ring, lock it in place and put it in as an assembly. Easy peasy.
oilhammer
www.cardocautomotive.com
Old October 9th, 2019, 08:07   #5
POWERSTROKE
TDI(s): 2002 Golf
Do you need to drain the coolant or the thermostat?
Old October 9th, 2019, 08:14   #6
oilhammer
oilhammer's Avatar
In the time it takes to read this thread, you could have replaced the thermostat.
Yes, there will be coolant that gets spilled. The thermostat lives in the water cooling system. You can drain the coolant from the drain and get some out, but you'll still lose some more with the CTS and thermostat.
oilhammer
Old October 10th, 2019, 05:01   #7
Powder Hound
Powder Hound's Avatar
You'll lose less than a gallon (diluted) if you don't collect coolant from the radiator. You'd just bend up the hose you pull off the end of the thermostat flange when you pull that.
I just did one because I failed to replace the thermostat properly and it leaked. Replacing the thermostat with a new one and new o-ring cured my long to warm up times. A leak like mine works the same as a thermostat that is failing open. And doing the sensor if you care to will not lose any more coolant since it is already out of the block from the t-stat change.
Cheers,
PH
16512 code coolant related seaglf VW MKIV-A4 TDIs (VE and PD) 20 February 7th, 2015 16:19
CEL 16512 - Coolant Thermostat Valve (N214)-P0128 richmondvatdi VW MKIV-A4 TDIs (VE and PD) 1 July 26th, 2012 18:38
16512 Coolant Valve (N214) Brian_Spilsbury TDI 101 2 July 19th, 2008 01:25
Code 16512 chewbacca TDI 101 1 October 7th, 2007 20:47
DTC: 16512 Coolant Valve Tmp Below Range (Local) aburchell44 Atlantic Canada 1 July 12th, 2005 06:48
Page generated in 0.15868 seconds with 11 queries
[Output: 82.10 Kb. compressed to 71.04 Kb. by saving 11.06 Kb. (13.47%)]
