Old October 5th, 2019, 16:57   #1
erasedhammer
TDI(s): 1996 Passat
Default Temp gauge dead, but vagcom picks up coolant temp
1996 Passat TDI.
Temperature gauge in gauge cluster always shows nothing, seems completely dead.
Hooked up my vagcom scanner and it can read the coolant temperature just fine.
Does this mean that the gauge is the problem and not the actual sensor?
erasedhammer is offline   Reply With Quote
Old October 5th, 2019, 17:21   #2
Nuje
I don't know about the Passat, but there are four pins on the Mk4 G/J/B cars. I don't know the pin-out, but I'd guess that one goes to the gauge, one to the computer, one for ground and one for...good luck(?).
Who knows. But I've seen something similar on one of my G/J/B cars, and sure enough, replacing the coolant temp sensor made everything work properly again.
Again - I may be way off base, but that's my $.02. Open to correction.
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, DSG tune
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is online now   Reply With Quote
Old October 5th, 2019, 19:18   #3
Mongler98
not uncommon for the cluster to have issues, i would not be surprised if the wiring harness behind the dash is damaged or that the PCB has started to delaminate the solder points. easy way to find out, pull the cluster out, its very easy to do, test the wires coming into it for the cluster and inspect the cluster and or test it, not sure what the volts and ohms range is supposed to be for the coolant gauge but im sure someone else can chime in.
I would just get a scangaugeII and put it some place easy to see without taking your eyes to far from the view ahead. the temp gauge was and is fairly uselss as it has a wide range that just shoes strait up normal temp reading. you can start to overheat the engine and the gauge will still say its ok. worthless POS vw garbage.
Old October 5th, 2019, 20:28   #4
erasedhammer
TDI(s): 1996 Passat
Yeah I wouldn't mind it, only the coolant light is flashing at me. I figured they are connected problems... maybe just low coolant.
Old October 6th, 2019, 08:44   #5
JETaah
Fuel Economy: 53 max, 42 min, average 46
Could be that the reservoir's probes for the coolant level are coated with funk and giving a false reading if your coolant level appears to be right. On A4 cars they are exposed where you can run a brush across them to clean them. Don't think that they are accessible on the Passat's reservoir.
If that is the case then a replacement reservoir is not that expensive.
https://www.idparts.com/coolant-expa...b4-p-1157.html
But do a continuity check on the harness leads to the ECU or cluster...don't remember if they go straight to the cluster or not.
Do you have any signs of contamination (bathtub ring) in the reservoir?
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old October 7th, 2019, 11:06   #6
erasedhammer
TDI(s): 1996 Passat
I think it's just dirty on the outside.
I'll check it today, but I don't recall seeing any fluid in there....
Engine still stays at temperature, IR temp monitoring, so I never bothered to check the coolant level
Old October 7th, 2019, 11:15   #7
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
1996 Passat TDI.
The scan tool data comes from the Engine controller side of the CTS, not the gauge side. And on that car, the Instruments work a little differently than the newer cars.
The sensor for the older cars used to be 357-919-501-A but got superceded to 6U0-919-501-B some time in the last decade. I would try that first, cheap and easy.
oilhammer
www.cardocautomotive.com
Old October 7th, 2019, 18:26   #8
AndyBees
AndyBees's Avatar
Temp sensor is the problem .. follow Oilhammer's advice.
The same issue is going on with my 03 TDI Jetta, the gauge is on zero. I plan to change it when I do the TB job. I've seen this numerous times.
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
Old October 7th, 2019, 19:11   #9
Mongler98
so why then does my 98 jetta have a 0 reading on the scangauge when i disconnected the temp sensor on the upper hose? i thought the b4 and the jetta both had nearly the same engine?
Old October 8th, 2019, 04:53   #10
oilhammer
oilhammer's Avatar
That is not the sensor we are discussing. That is for the A/C and A/C alone. Has zero to do with the Engine controller, or the gauge in the Instruments.
oilhammer
Old October 8th, 2019, 06:15   #11
Mongler98
Sorry, not on the hose. On the plastic tee on the head to the radiator hose. Sorry I was not specific
Coolant temp gauge Cha2ga VW MKIV-A4 TDIs (VE and PD) 3 April 29th, 2015 06:41
Replaced the coolant temp sensor. fixed short GP cycle, now temp gauge is wrong. 2TDIguy VW MKIII-A3/B4 TDIs 3 October 21st, 2010 18:55
coolant temp gauge prob johnjames1234 TDI 101 13 February 18th, 2010 15:38
Coolant Temp Gauge SheeB Ontario 4 February 9th, 2009 17:30
Fuel temp, charge air temp, coolant temp??? Turbosprezarka TDI 101 3 December 5th, 2006 17:03
Page generated in 0.17588 seconds with 11 queries
[Output: 106.24 Kb. compressed to 90.37 Kb. by saving 15.87 Kb. (14.94%)]
