Old October 2nd, 2019, 18:37   #1
TurtleTom
Question Limp mode with no dash light?
Hi I have a slight issue but no dash light. The car is a Passat B6 TDI 1.9
It has happened twice within the last week and both times (maybe coincidence?) have been from first starting the car, not middle of a journey)
There is literally no power what so ever when it happens. I would imagine this is limp mode after trawling online but there is no dash lights. The first time I drove around to let engine heat up before I tryed being a bit more aggresive but nothing struggling pushing like 60mph in 5th gear so decided to come home. When I got home I turned it off and thought I would try again and it was fine. Has been fine since done about 100 miles and if anything it feels more powerful (the car wants to wheelspin now &#128545
2nd time was today, went out in the morning and went to 3/4 places all was well........ come home and about an hour later had to pop back out but the car had a lack of power again, this time I pulled over took key out, locked car, unlocked car, put key in and off I went absolutely fine. Again no dash light or warning though.
The car will be scanned tommorow hopefully but as there has being no lights will the ECU log it?
I am aware it could be many things such as MAP sensor, MAF sensor, N75, actuator, sticky veins to name the main culprits but these come with a dash light so any one have any reasons as to why this is happening?
TurtleTom is offline   Reply With Quote
Old October 2nd, 2019, 19:57   #2
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
Yes, limp mode will not always turn on the MIL, but there will be a code stored in the ECU. please report back after you have done the scan.
-George Bernard Shaw
Light throttle limp mode mrschilly TDI 101 0 May 17th, 2018 20:34
flashing dash lights and limp mode skyhawkone VW MKV-A5 Golf/Jettas 4 April 14th, 2016 11:27
Check engine light-glow plug light & limp mode Slothbar VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 17 November 30th, 2013 11:30
Flashing Glow Plug Light and Limp Mode - No Check Engine Light southbostontdi VW MKV-A5 Golf/Jettas 3 February 11th, 2013 14:28
NEED help engine light is on and car is in limp mode 2002tdipower Ontario 6 June 20th, 2009 08:30
Page generated in 0.13018 seconds with 11 queries
[Output: 53.24 Kb. compressed to 49.21 Kb. by saving 4.03 Kb. (7.57%)]
