Old October 2nd, 2019, 08:02   #1
TdiRN
Fuel Economy: 41-46mpg
Default Battery charge now check engine light??
Charged my battery in the car over the weekend. I have the amp draw issue but that is another issue for another time. After I got done charging the battery my check engine light came on with the Auto transmission codes - I did the 5 speed swap 70k miles ago. I used vagcom and went in and the transmission is still coded to manual. I've cleared the codes several times but they keep coming back.
Any ideas?
2002 VW Jetta TDI auto->5speed conversion, Malone Stage 1
2011 F150 4x4 SuperCrew Ecoboost - 5star 93 octane/adaptive octane tunes
2017 Toyota Sienna XLE
TdiRN is offline   Reply With Quote
Old October 2nd, 2019, 08:34   #2
eddieleephd
Fuel Economy: 38mix / 47@70-75
I would assume you disconnected the TCU, if not that could be the culprit. Mine still says no comm with TCU.
Sent from my Armor_2 using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Bosio DLC 1020's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is online now   Reply With Quote
Old October 2nd, 2019, 08:37   #3
TdiRN
I haven't had any engine lights in the last 3 years until sunday. If the TCU is unplugged - what would have caused it to suddenly start throwing codes?
Old October 2nd, 2019, 09:25   #4
boertje
boertje's Avatar
When you did the swap, did you also set the can bus? I see you have a 2002 where is shouldn’t be necessary, however some are problematic.
On MY 2001 and earlier, go to CAN-bus gateway>coding and change the 7 to a 6 to remove the automatic transmission feature.
Look at the last digit in the coding. Add the values for the options together to get the correct coding.
0 - No available equipment
 +1 - Automatic Transmission
 +2 - ABS Brakes
+4 - Airbags
So, if you want to support Automatic Transmission, ABS Brakes, and Airbags, (add 1+2+4 = 7) = 00007. Note: 2002+ models do not need to be coded separately for automatic transmission, so a 2002 with Automatic Transmission, ABS Brakes, and Airbags, (add 2+4 = 6) = 00006. In my Golf, the coding was 7 so I changed it to 6 which subtracted the automatic.
Not necessary on MY 2002 and later. However, It has been discovered that some 2002 and later cars are having TCU communications error codes even though the wiring and coding was done correctly. If the 19-CAN Gateway is checked with these cars, the value is 6 as it should be. What is interesting (thanks to “the*rogue” for this one) is that if the value is changed to a 6, which it already is, and saved, it forces the ECU to rescan the devices and finding no TCU, it is now happy and the codes do not reappear.
Make sure you cycle the key after each change and then check for fault codes.
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is offline   Reply With Quote
Old October 2nd, 2019, 09:35   #5
TdiRN
Honestly I had a VW shop do the swap. So I can't be 100% sure.
If I go in there and change the can-bus to a 6 (assuming it hasn't been) would that mess anything up?
Old October 2nd, 2019, 09:49   #6
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Originally Posted by TdiRN View Post
.............................. I have the amp draw issue but that is another issue for another time........................
Any ideas?
Maybe that draw is one of the TCU wires shorting or grounding and the ECU sees that.
Old October 2nd, 2019, 10:08   #7
boertje
boertje's Avatar
No, it won’t mess up anything. It most likely will already be 6 but the key is to get the ecu to rescan so “change” it to 6 again and save.
If the 19-CAN Gateway is checked with these cars, the value is 6 as it should be. What is interesting is that if the value is changed to a 6, which it already is, and saved, it forces the ECU to rescan the devices and finding no TCU, it is now happy and the codes do not reappear.
Old October 2nd, 2019, 10:10   #8
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Yeah, it sounds like the CAN Gateway just needs to be "retold" what modules it has to watch over.
oilhammer
www.cardocautomotive.com
Old October 2nd, 2019, 11:05   #9
TdiRN
Should the TCU be plugged in OR unplugged
Old October 2nd, 2019, 12:00   #10
BobnOH
not-a-mechanic
Unplugged, gone even.
Old October 2nd, 2019, 16:51   #11
boertje
boertje's Avatar
^^ what bobnoh said.
Old October 11th, 2019, 08:12   #12
TdiRN
I did the CAN/bus thing last night. This morning the light was still off so we will see.
On a semi-related topic is it possible to disable the driver seat side airbag with Vagcom?
Old October 14th, 2019, 06:40   #13
TdiRN
Damn light came back on. I do have a glow plug code which I need to fix. I wonder if whenever a legit code is thrown it will pull all 20 codes for the auto tranny?
Battery Replaced - Check Engine Light On AlphaxTDI VW Passat Family (NMS and B7) TDIs (2012+) 3 August 22nd, 2014 21:56
Does anybody sell a vacuum hose kit?Check Engine Light: 17964 Charge Pressure Control austi012 VW MKIV-A4 TDIs (VE and PD) 1 August 19th, 2014 07:28
Battery / generator light on, alternator not charging, battery holds charge Keven VW MKIV-A4 TDIs (VE and PD) 16 December 12th, 2013 14:22
After battery replacement, check engine light on, glow plug light flashing ... redluv VW MKIV-A4 TDIs (VE and PD) 7 June 28th, 2011 11:59
Check Engine Light: 17964 Charge Pressure Control jasonngan VW MKIV-A4 TDIs (VE and PD) 15 September 10th, 2005 13:24
Page generated in 0.16106 seconds with 11 queries
[Output: 115.80 Kb. compressed to 97.12 Kb. by saving 18.68 Kb. (16.13%)]
