Old October 1st, 2019, 00:38   #1
Filip74321
Default Hessitation and running on 3 cylinders
Hi all,
First time posting here.
I seem to have an odd problem, i have searched the forums, but can't seem to get a solution to this problem. The vehicle in question is a 2005 VW Caddy 1.9 TDI. The car works perfectly, idles normally, but as soon as You press full throttle(over 2500rpm, and mostly in 3. Gear), it starts juddering, shaking, and sometimes beggins running on three cylinders after that. I have put some würth diesel system cleaner, but that changed nothing... So i also went and replaced the fuel filter yesterday(was completly black), the car runs a little better , but the issue is still there, the car doesn't smoke that much, only under that hard acceleration i get a burst of black smoke, which i suppose is normal. Also, forgot to say, i got a check engine the day before i took it to a mechanic, "abgas werkstatt"(emmision workshop). Any help is aprrecieted, i am really hopping that the injectors are fine.
Filip74321 is offline   Reply With Quote
Old October 1st, 2019, 08:30   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
OBD works. Start there. You know the MIL is on, what DTC(s) are stored?
oilhammer
www.cardocautomotive.com
Old October 1st, 2019, 08:44   #3
Filip74321
Sorry, i completely forgot to mention that the next morning, the check engine went away and hasn't appeared since. But i am still stuck with the problem. To be honest, i am just bothered by the fact that it could get worse, since it currently doesn't impact my daily commute at all, i rarely push the car above 1500, 2000 rpm, could it possibly be a clogged intake manifold? Or a clogged cat?
Old October 1st, 2019, 08:46   #4
oilhammer
oilhammer's Avatar
We can guess all day.... OBD is there for a reason, and it works. Embrace it. Find out what the DTC is.
oilhammer
Old October 1st, 2019, 09:05   #5
Filip74321
Hahah, thanks.
I will take it to the dealer as soon as possible then, to check for codes, and hopefully have this sorted out. This is btw my first Volkswagen, and the car has served me amazingly since i bought it, this is the only issue i have to report so far, it has covered 250.000km, which i suppose isn't to much for these engines. Thank You once again for the quick response, and i will post an update about the problem.
Misfire running on 3 cylinders Chrismak VW B5 Passat TDIs 233 March 29th, 2019 15:39
This could be serious. Running on two cylinders The Turtle VW MKIII-A3/B4 TDIs 52 December 14th, 2013 09:18
help - engine three cylinders running TDICrazier VW MKV-A5 Golf/Jettas 28 March 3rd, 2011 11:08
Running on three cylinders blued TDI 101 20 September 12th, 2010 12:26
running on 3 cylinders? tdiwesty VW MKIII-A3/B4 TDIs 5 June 1st, 2006 12:32
Page generated in 0.14126 seconds with 11 queries
[Output: 70.65 Kb. compressed to 62.67 Kb. by saving 7.98 Kb. (11.30%)]
