Old September 30th, 2019, 18:16   #16
jmodge
Pull every off you want in the sitting position, including fuel, and roll it over on it’s top to pull everything from underneath. It will easily slide on a flatbed. I thought you were a hillbilly, very disappointing.
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old September 30th, 2019, 19:50   #17
STDOUBT
STDOUBT's Avatar
I was actually going to suggest that.
Just pull the engine first off, then flip it over!
Sorry for your loss, too Mongler.
2003 Jetta TDI 1.9L 5-speed
Malone Dynamic EGR ~ cooler delete ~ Euro pipe ~ ventectomy
Search Tip: search this site best by using Bing: tdiclub topic
STDOUBT is offline   Reply With Quote
Old October 1st, 2019, 07:11   #18
Mongler98
What am I? The hulk?
Old October 1st, 2019, 07:18   #19
eddieleephd
Fuel Economy: 38mix / 47@70-75
It really only takes a few buddies to roll one over. Difficult part is getting the fuel out and the exhaust apart to remove the engine. Reality is that only one side needs to be up far enough to access the exhaust and the engine is much easier to pull in it's natural position.
You should consider raising the side with the muffler, and removing the exhaust, or lifting one end at a time. That way you get more lift for your jack stands
Sent from my Armor_2 using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Bosio DLC 1020's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old October 1st, 2019, 07:20   #20
jmodge
According to your self description, I would say the bulk
Old October 1st, 2019, 09:02   #21
Mongler98
Good one. Made me laugh. Hard to tell when you guys are trolling me. I'm not flipping the car, not enough room in the garage to do it and I've seen those car rollers and I've seen birdmans diy plywood rig for flipping his car on his restoration, seems like something I'm not willing to spend the money or time on. I cant really just set up one side at a time as I'm taking the sull suspention system off it.
How much room do I need to drop the fuel tank and get it out from under the car? I'm assuming the neck does not need to clear underneath as it comes out the wheel well right?
Old October 1st, 2019, 17:58   #22
VincenzaV
VincenzaV's Avatar
Fuel Economy: Better than a tank, worse than a cyclist.
Jmodge-I laughed so hard litteraly sh*t myself .. luckily...I was on the toilet at the time...lol
I'm sorry for laughing at your expense Mongler98. I'll put a twenty in the swear jar. The "laugh at others expense" jar is obviously full...
VincenzaV is offline   Reply With Quote
Old October 1st, 2019, 18:08   #23
fouillard13
why not just make some 2x4 cribbing blocks? we used them in the oilfield all the time and set ridiculously heavy things on them... theyre solid. the wood hardly compresses and with short lengths like that are almost impossible to have snap on you. I personally wouldnt trust masonry blocks but thats just me. railway ties or wood would be a way safer option IMO.
the main problem is sinking into soft ground but sounds like you got that covered.
when my gf was 10 years old she was walking home from school and heard a guy screaming.. he had his car up in the air and just his legs under the car, it fell and crushed his legs and he was stranded there until she ran for help. its made me paranoid ever since.
fouillard13 is offline   Reply With Quote
Old October 1st, 2019, 18:58   #24
eddieleephd
If you get the back wheels off the ground with the axle extended you're high enough. It's only about 14 inches thick. Not sure on the mk3 necks, mk4 is definitely two pieces, top is plastic.
The cribbing blocks are a good option, I would stop at an even height as to the width for stability.
Old October 1st, 2019, 20:10   #25
turbobrick240
turbobrick240's Avatar
The cribbing under that rustang is not suitable/safe to work under. But cribbing is a good idea when it's constructed properly.
Old October 2nd, 2019, 06:44   #26
jmodge
Well mongler, here’s hoping you don’t make National News due to the event of injuries . Unusual phenomenon, maybe
Old October 2nd, 2019, 07:03   #27
251
TDI Owner/Operator
The biggest thing is to make sure whatever you do is safe to push and pull and lean against before you get under it. The rest is on you.
Listen to this man - he literally had a TDI resting on him once - for real, no joking here!
251 is offline   Reply With Quote
Old October 2nd, 2019, 07:35   #28
Mongler98
I've always shaken the death from every thing I have put on a lift
Old October 3rd, 2019, 07:55   #29
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
If you're scrapping the car, why take the engine out the top? Take the core support off, unbolt the subframe, and take it out the front.
Present:
2018 Tesla Model 3 DM. 20,000 miles.
2014 Cadillac ELR. 34,000 miles.
2013 Fiat 500e. 28,000 miles.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old October 3rd, 2019, 16:16   #30
Dannyboy
Dannyboy's Avatar
Fuel Economy: All good on the motion lotion
https://giphy.com/gifs/engine-removal-vw-tbXn639KCmpEY
If you have some room in your garage, I highly recommend quick Jack 5000lbs. Expensive but way better way to work under a car. I have one and makes for an easy lift and is very secure. And lowering is controlled smoothly. Best option shy of having a post hoist
Cheaper way is the crib it, it's done to construction machinery all the time. Just use hardwood.
Dannyboy is offline   Reply With Quote
Newbie Ripping My Hair Out! GrizzleFace27 VW Passat Family (NMS and B7) TDIs (2012+) 11 June 14th, 2016 08:51
Stealership Ripping me off?!? TyeRant VW MKIV-A4 TDIs (VE and PD) 10 October 12th, 2005 17:12
Photos from Volkswagen Stand at Car Show erickordt General VW Discussion 3 April 24th, 2005 09:42
Problem w Jetta bumpers ripping on parking stops? Oberkanone General VW Discussion 25 June 10th, 2004 21:52
Diesel's Last Stand: Car & Driver March 2004 jchagtdi TDI News/Tech 92 March 15th, 2004 14:43
Page generated in 0.17494 seconds with 11 queries
[Output: 130.47 Kb. compressed to 109.20 Kb. by saving 21.27 Kb. (16.30%)]
