Old September 26th, 2019, 13:04   #1
Noseve
Default Simulate kerb weight using jack?
Hi - when re-fitting rear shock-absorbers, I understand that torque of the lower mounting bolt should be set with the wheels on the ground. Having said that, it doesn't look as though my torque wrench+ socket will fit with the springs in place.
Alternatively can I, before removing the wheel, record the measurement from the centre of the wheel to a reference point directly above it, then after the shock is in place, jack up the hub to create that same distance from hub centre to my reference point and tighten to correct torque?
Does it matter whether the spring is in place when jacking up?
Any thoughts, or better still, definitive answer would be really appreciated. Thanks.
Noseve is offline   Reply With Quote
Old September 28th, 2019, 08:49   #2
soot1
If it isn't possible to get in there with a torque wrench and a socket, can you still reach the bolt with a simple box-end wrench or some other "unsophisticated" tool? My thinking is that this is just a simple bolt that holds a shock absorber in place, and the torque applied to the bolt really doesn't matter all that much, as long as it is tight "enough".
I do not see anything wrong with the idea you proposed here. By jacking up the hub, you are simulating the force that compresses the absorber when the wheel is on the ground, and it should not matter whether the absorber is in place when you jack up the car, as long as the bolt is loosened during the jacking, and tightened only after you reach the correct distance you determined earlier.
soot1 is offline   Reply With Quote
Old September 29th, 2019, 02:38   #3
Noseve
Thanks, Soot1. I have reached the conclusion that it is not so much the weight, as the amount of compression that matters, so the same distance should achieve that. In which case, it follows, it should make no difference that I'm going to be doing it with the spring removed. I appreciate what you say about the tightness, but for suspension parts I'd rather use the torque wrench. I have only just bought it, with this job as justification for doing so, after all!
Old September 30th, 2019, 06:11   #4
JETaah
Fuel Economy: 53 max, 42 min, average 46
If there is not enough room to swing a torque wrench when it is on it's wheels you can first tighten the bolt enough to hold the bushing in position. It does not take that much. Then, lift it and finish torquing the it to the correct reading.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Broken 3.5 mm Jack in auxiliary jack 2009 Jetta wagon Sportswagster TDI 101 0 March 24th, 2016 20:32
borrow a set of floor jack, jack stands (or ramps) in Seattle area Xuchen West Coast Canada/USA 0 June 11th, 2012 12:59
Where to put the floor jack or jack stands tclemmer TDI 101 29 May 1st, 2011 07:26
Sugestion for a How-To - Jack Points and Jack Stand Location flash9 TDI 101 9 October 5th, 2008 08:07
Best place to jack New Beetle up for Jack Points amishman VW MKIV-A4 TDIs (VE and PD) 3 June 30th, 2007 14:07
Page generated in 0.09381 seconds with 11 queries
[Output: 63.13 Kb. compressed to 56.71 Kb. by saving 6.42 Kb. (10.17%)]
