Old September 25th, 2019, 22:54   #1
yabay
Default PD injector 038 130 073 AG & 038 130 073 AK
Hi guys! Can ayone tell me the difference between 038 130 073 AG & 038 130 073 AK
My stock injector was 038 130 073 AG, I'found a cheap deal for a 4 set of AK coded set and put on to my TDI but, Car started to black smoke at low rpm's and heavy smoke at full thorttole.....
The dealer said there was no difference between thoose injectors other then the last two digits.
I have stage 1 tuning map, I've loaded the stock map and doesen't changed anything about the smode.. MPG is sufering.
The computer shows 0.3LT/H and mgp/s is around 3.5 with tunng map and AK injectors.
If these injectors were for PD130, can i change the nozzleswith stock ones to make them run proper?
yabay is offline   Reply With Quote
Old September 26th, 2019, 02:40   #2
tdi_my live
TDI(s): Skoda Fabia
073AG is a P1.1/80/520 PDE
073AK is a P1.3/80/465 PDE
What engine Code your car have?
tdi_my live is offline   Reply With Quote
Old September 26th, 2019, 02:43   #3
yabay
Thank you for your answer..
2005 BJB
521 and 465 is nozzle size, then the other parameters?
Which one is more economical in the MPG?
Where can i get these information on the web do you know?
Old September 26th, 2019, 04:20   #4
tdi_my live
TDI(s): Skoda Fabia
520 is the size of the PDE
465 is correspondingly smaller and would require larger production periods to promote de same amount.
So your car would run too lean.
Your sure the AK PDEs are good?
Old September 26th, 2019, 04:31   #5
arazvan2002
arazvan2002's Avatar
038130073AG 0414720265 is PDE1.1/80/425, so smaller than 038130073AK 0414720038 PDE1.3/80/465, so there are 2 problems.
One is that bodies (coils) of the injectors are different, so different BIP maps which leads to rough running in some conditions, and second, the AK injectors have bigger nozzles (hence the smoke).
A4 B6 1.9 TDi AVF quattro - development in progress: remaped, GTB2056VL. ARL inj, FMIC, 320/288mm B7 brakes, OEM Sport suspension, B7 Steering wheel MFSW.
arazvan2002 is offline   Reply With Quote
Old September 26th, 2019, 06:13   #6
yabay
I'm confused about you explaination... Could you make it clear?
Old September 26th, 2019, 08:05   #7
arazvan2002
You had 038906073AG on your engine. These are 425cmc .
You installed 03813073AK which are 465cmc, so like 10% bigger than yours.
Apart from the difference between nozzles, there is a different between the injector bodies which need to be modified in the software, BIP maps, exactly.
Old September 26th, 2019, 08:26   #8
yabay
@tdi_my live are you sure about 520??
If AK is bigger than AG, so why cars power suffering in high gears?
Old September 26th, 2019, 08:33   #9
yabay
I know I ask a lot of questions, İ dont know what BIP means.
Aha ok BIP = Beginning of injection period
Old September 26th, 2019, 08:45   #10
tdi_my live
TDI(s): Skoda Fabia
I got wrong information. The AG are only 425 and not 520.
The AK are bigger, so the SOI and duration should be rewritten properly in the file.
Therefore, the now drives a filthy Lambda.
Old September 26th, 2019, 08:53   #11
arazvan2002
What Ecu do you have, EDC15 or 16? If it's EDC16, it's a little harder to copy BIP maps from EDC15 (because I don't know any car that uses PDE1.3 on EDC16.
Old September 26th, 2019, 13:00   #12
yabay
Unfortinetaly EDC16..
Old September 27th, 2019, 07:18   #13
tdi_my live
TDI(s): Skoda Fabia
What ECU Number and Version?
Can you flash at self?
Old September 30th, 2019, 00:14   #14
yabay
I'll write the ecu number;
Yes i did the flash my self.
Old October 8th, 2019, 21:56   #15
yabay
Sorry for the late answer.
FS BRM injectors (038 130 073 BN) mr.loops Private TDI Items for Sale/Wanted 18 November 7th, 2019 16:03
B5.5 Passat BHW 2.0L PD Injectors: 038-130-073 BB PDB 034 nkfry Private TDI Items for Sale/Wanted 1 October 21st, 2016 15:40
PD injectors 038-130-073-BF loluspololusTDI Vendor & GroupBuy items for sale 2 October 1st, 2015 19:21
Four PD130 injectors 038 130 073 AL devonutopia Private TDI Items for Sale/Wanted 4 July 4th, 2012 15:27
Brand new PD injectors 038 130 073 AG ryanp Vendor & GroupBuy items for sale 5 April 17th, 2010 18:34
Page generated in 0.16895 seconds with 11 queries
[Output: 120.42 Kb. compressed to 99.89 Kb. by saving 20.52 Kb. (17.04%)]
