Old September 25th, 2019, 21:12   #1
jfuhr
Default Anyone have a set of BEW injectors to sell me?
I'm driving a 2005 Jetta TDI with a BEW 1.9L. 240k miles. It's hit or miss whether I'm going to be driving on 3 cylinders from day to day....usually it runs fine in the morning but then a dead miss on the way home from work.
Injector CEL, I want to replace the offending injector (#2) but it would me nice to replace all four (4).
Does anyone have an old set laying around they would sell me? or what would be the best place to buy a single injector?
BTW: no smoke or unburned diesel smell. Fuel Eff. steady at 43mpg.
jfuhr is offline   Reply With Quote
Old September 26th, 2019, 00:47   #2
Henrick
I'd strongly suggest to start by replacing the injector wiring harness first. In most cases it is the problem. Besides, at that mileage yours is hard and brittle, so you will need it anyway
Henrick is offline   Reply With Quote
Old September 26th, 2019, 04:55   #3
Tdijarhead
I read your thread and then happened to be looking at Craigslist. I found this add. I have absolutely no idea who this is, you will need to do due diligence on these parts if you’re interested. I just thought I’d pass it along.
https://washingtondc.craigslist.org/...983797607.html
Tdijarhead is offline   Reply With Quote
Old September 26th, 2019, 10:36   #4
jfuhr
Great suggestion. Thanks so much. Sorry to be so needy, but would you mind recommending an on-line supplier?
Old September 26th, 2019, 10:40   #5
jfuhr
thanks a lot for passing this along....good of you. Based on the intermittent nature of my issue I'm going to pursue Henrick's suggestion first.
As a first time poster, TDIJarHead and Henrick gave me royal treatment....I really appreciate it and hope to pass it on.
Old September 26th, 2019, 19:17   #6
Tdijarhead
Here is an oem one from idparts.com. Idparts is a forum supporter and great folks to deal with.
https://www.idparts.com/injector-har...rm-p-2318.html
Old October 3rd, 2019, 18:39   #7
jfuhr
thanks for you help yet again. I just placed the order from IDparts.com
Old November 7th, 2019, 18:41   #8
jfuhr
hi guys, I took Henricks advise and installed a new injector harness from ID parts and my primarily complaint symptom (intermittent stuttering/miss) disappeared. Thanks guys...
The only thing that didn't clear up is a low boost cel. I bought a mityvac and tried to draw a vac on the line to the turbo actuator. I could not generate vac so I bypassed the hose and connected directly to the actuator and still could not generate vac.
Question: Does this confirm that I have a bad actuator? I'm questioning b/c there is a electrical connection to the actuator and I don't know what it's purpose is....I was thinking that there could be some integrated solenoid vent that is normally open...but that doesn't seem likely. Does anyone know what the electric component to the actuator is?
thanks in advance, Jfuhr
Old November 7th, 2019, 20:15   #9
chz17
If you turbo charge actuator can't holding vacuum, it's bad.It has a sensor build to the rod inside the actuator. The ECU use the sensor monitor the rod movement.you may read this [http://forums.tdiclub.com/showthread.php?t=312966]
chz17 is offline   Reply With Quote
Old November 8th, 2019, 18:05   #10
jfuhr
thanks a lot chz17!
FS: Set of (4) BEW PD100 Fuel Injectors pizza pig Private TDI Items for Sale/Wanted 14 August 20th, 2017 17:27
FS: PD100 BEW Injectors - Complete Set brs Private TDI Items for Sale/Wanted 1 September 6th, 2013 09:28
Anyone have a spare set of injectors / nozzles they want to sell? vwmikey99 Ontario 3 June 25th, 2013 17:26
FS: BEW injectors, set of 4, 038130073AG(038130073BF) bpardoe Private TDI Items for Sale/Wanted 1 December 7th, 2011 09:06
Need to sell new set IDI VW QuickSilver injectors TomJ Private TDI Items for Sale/Wanted 0 May 9th, 2005 07:47
Page generated in 0.14893 seconds with 11 queries
[Output: 93.45 Kb. compressed to 79.54 Kb. by saving 13.91 Kb. (14.89%)]
