**UPDATE** so what ended up being the problem is that one of the wires going into the plug for the FCM actually came of the pin within the connector so once that was fixed now the fans work as they should
I have mk4 jetta alh tdi and my issue is that the radiator fans wont turn off even after the car has shut off with the key out of the ignition.
i have replaced the fuse box on top of the battery along with the cable the goes to the alternator and the one that goes to the stater
the car has also had 3 different fan control modules in it and still having the same problem
i have tried to unplug everything temperature sensor under the hood one at a time to see if the fans stop and i got nothing from that either
any advice would be greatly appreciated thank you
