biodieselboy
https://www.hotshotsecret.com/shop/lx4-lubricity-extreme/
They posted test results with wear scar ratings as well.
I wonder if it stinks to high heaven.
I agree that the results look good, specially on un-additized D2. It looks like 2 oz is getting you the most bang for the money in a typical TDI fill up (let's say around 16 gallons).The testing reports look good. Down around 250 or less for the ASTM D6079 testing. At two ounces per tank, it is about $1.80 per 15 gallon tank or .12 cents per gallon more. I may try it though just because I have tested most others. The high lubricity/low wear sounds good. Even non treated fuel tested very well. Pump fuel too.
Thanks for posting the results biodieselboy.
