Old September 12th, 2019, 02:08   #1
Texas_sky
Fuel Economy: unknown at the time, waiting for engine swap
Default What is the correct part # for 2006 TDI DSG Transmission?
I was sold a 02E 301 103 G from a junk yard, they said it would fit a 2006 jetta tdi. I was wondering if anyone can't point me to the right part number to confirm which transmission I have. I looked it up on ebay and it said that that part number 02E301103G fits Passat Eos and CC. Hopefully they are interchangeable or it looks like they will have to swap for correct one or find another one.
Texas_sky is offline   Reply With Quote
Old September 12th, 2019, 03:36   #2
JETaah
Fuel Economy: 53 max, 42 min, average 46
You need to find the 3 letter code of your transmission which is usually under the mat in the trunk or the spare tire well. The engine code and the transmission code is on the sticker i.e., BRM (engine) then HXU or HQN (trans).
If your car is a TDI and they are giving you something that will fit an EOS or CC then it is doubtful that it is the right part since those cars did not come with diesel engines in the US. The transmissions themselves are stamped rather inconveniently under the adapter plate that the trans mount attaches to.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is online now   Reply With Quote
Old September 12th, 2019, 04:09   #3
Tdijarhead
If it came from a gasser it may fit but the gearing will be wrong.
Tdijarhead is offline   Reply With Quote
Old September 14th, 2019, 02:02   #4
Texas_sky
Can I find the HXU or HQN on the transmission somewhere because the cars that the transmission came from is no longer available to check the trunk codes. I bought two of these transmissions one with 40k other with 60k from a reputable salvage yard in So Cal so I'm sure they would let me exchange for right ones.
https://www.yelp.com/biz/german-kore...ntington-beach
Old September 14th, 2019, 18:39   #5
turbodieseldyke
turbodieseldyke's Avatar
TDI(s): 98 jetta
Fuel Economy: 50
Originally Posted by Texas_sky View Post
I'm sure they would let me exchange for right ones.[/URL]
If they had the right ones, they would've sold you the right ones. If they allow exchange, it might be some time before they get what you need.
Your tranny # is closer to 02E 300 043
Good luck.
turbodieseldyke is online now   Reply With Quote
Old September 15th, 2019, 01:57   #6
JETaah
If you re-read my post you will see where it is stamped on the transmission.
Old September 15th, 2019, 12:43   #7
Texas_sky
Ok thanks, I'll turn the transmission upside down and take a look at the code to determine what vehicle it came from and report back.
Old September 15th, 2019, 14:24   #8
JETaah
It is not on the bottom. It is on the top side under the bracket next to the transmission mount. You will have to support the transmission from underneath and remove the 4 bolts that mount the bracket. Then lower the transmission a bit so you can see under the bracket or detach it from the chassis mount and slide it to the side . Didn't I tell you how inconvenient it was?
If your trans is dirty and corroded you might have a hell of a time trying to read it. That is the only place that I know of where the trans is marked with the code. I don't think that it is identified in the software if you to call up the trans controller with VCDS.
If you still don't understand where it is I can get a pic of it.
Old September 16th, 2019, 02:33   #9
Texas_sky
The transmissions are out of the car and in storage right now. I'll take a look soon to see what I can find. If you could post a picture that would be informative.
Old September 23rd, 2019, 13:57   #10
Texas_sky
I just found a 02E 301 107 part number on top marked AT S AK AH AP
also found a real small marking 28 01 13KN 06 49
Old September 23rd, 2019, 14:40   #11
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
It is UNDER the mount bracket. It will be a 3-letter code, HXU or HQN.
Take the four bolts that hold the mount bracket on to the top of the transmission case off, and it will be under there.
oilhammer
www.cardocautomotive.com
Old September 23rd, 2019, 14:51   #12
Texas_sky
I'll take a picture of it, I think those were scratched off or removed. I'm going to call the yard and see if they can just do a return or exchange. Can anyone post a pic of the 3 letter code on transmission to get a idea? I just looked up the listing on car-part.com and the yard I bought both transmissions from has those two codes oilhammer mentioned so that is good news.
Old October 9th, 2019, 10:43   #13
Texas_sky
Here is a top pic of the transmission, can anyone see the code from this angle?
https://denver.craigslist.org/pts/d/...968974792.html
Old October 9th, 2019, 10:51   #14
oilhammer
oilhammer's Avatar
It is etched on that flat spot shaped like a rectangle atop the case, right in the middle of the four big threaded holes where the mount bracket goes. It is pretty faint, sometimes cleaning it with some Scotchbrite pad helps.
oilhammer
Old October 14th, 2019, 02:22   #15
Texas_sky
By chance do you see the spot you're talking about in the picture on the craigslist link I posted? It looks like its not even there, like it was scratched off. I did see on the other trans, it's real hard to read but it looks like the other one w/ 60k is a HXU.
2006 DSG transmission CarolinaOwner VW MKV-A5 Golf/Jettas 18 November 27th, 2017 18:47
Wanted: 2006 jetta tdi dsg transmission ludiboris Private TDI Items for Sale/Wanted 0 October 22nd, 2015 09:47
2006 TDI (BRM) DSG transmission reinstall jjtoutt VW MKV-A5 Golf/Jettas 3 November 16th, 2014 18:41
Wanted - Automatic 6spd dsg transmission for a 2006 Jetta TDI MKV summerb Private TDI Items for Sale/Wanted 0 August 1st, 2012 00:16
Can't get my Transmission Back On - 2006 Jetta TDI DSG dmf ecaddy VW MKV-A5 Golf/Jettas 13 March 19th, 2012 10:16
Page generated in 0.18262 seconds with 11 queries
[Output: 131.87 Kb. compressed to 110.25 Kb. by saving 21.62 Kb. (16.39%)]
