Old September 17th, 2019, 19:46   #16
Bob S.
Do not forget to clean the connection of the fusible links & connections on the front of the engine space E-box. Corrosion there can cause similar issues.
Also, as others have said. Clean your grounds. All of them, every single one.
Verify a good battery charge.
A B4V, a CRUA & a couple BRMs & ALHs in the family.
Bob S. is offline   Reply With Quote
Old September 18th, 2019, 15:49   #17
Jerry.W
Battery is new. It was drained from testing on the second vcds scan. I have checked all grounds thoroughly. I have also removed, inspected, and replaced every fuse and relay. I replaced the can-bus module and the power distribution module. As far as the wire bundles, I removed the factory “loom” and inspected everything from the firewall to the ecu on both connectors, plus the longer bundle to the “y” at the left headlamp assembly. No broken or exposed wire.
ETA: I will test the MAF for voltage and the fuel pump relay.
ETA addendum: there is no stable voltage to MAF. I have to go to work, but for now I’ll ask for more information.
Does anyone have a diagram for the ecu pin connectors? I want to make sure I am getting proper power and grounding to the ecu.
Jerry.W is offline   Reply With Quote
Old September 23rd, 2019, 18:42   #18
Jbwoo
I had a very similar issue as you described. Ended up being the ECM relay in the fuse box in the engine compartment that was bad. It tested OK on the bench, replaced it on a hunch with an OEM relay, and haven't had the problems again. I pulled all kinds of wiring, checked power and ground everywhere in the engine compartment. Even de-loomed most of the power loom to the ECM.
What was happening is once the ECM warmed up it would pull more power than the ECM 501 relay could maintain, and would quit. As far as the best I could surmise.
15 GSW DSG and Kerma tuned 80k miles
06 Jetta DSG BRM no mods just maintenance 275k miles
04 Dodge 2500 Built auto trans, Cummins 50hp injectors, Firepunk HPTuning 160k miles
08 E450 Motorhome V10 powa, suspension mods
Jbwoo is online now   Reply With Quote
Old September 25th, 2019, 12:19   #19
Jerry.W
I replaced that relay with an oem relay very early.
Old September 25th, 2019, 20:38   #20
Jerry.W
Can anyone tell me what the voltage should be on T31? Mine is .1v
Old October 4th, 2019, 17:22   #21
Jerry.W
Default Update
I purchased a used ECM from a junkyard and it is communicating, but the immobilizer is now preventing a start. Who can help with programming?
Old October 18th, 2019, 04:00   #22
Jerry.W
Turned out to be the ECM. AARodriguez deleted the immobilizer. Thanks for the help!
help electrical issues and now no start. Mickey_09_TDI VW MKV-A5 Golf/Jettas 6 October 10th, 2013 10:13
Electrical - Hesitation on start Big Red VW MKIII-A3/B4 TDIs 5 July 30th, 2011 18:27
No start - electrical issues xiledsavior TDI 101 12 February 5th, 2011 21:01
Electrical no start problem Grumpyweasel TDI 101 0 February 26th, 2007 14:31
Electrical failure upon start up 2000golftdijack TDI 101 2 January 17th, 2007 01:03
Page generated in 0.15818 seconds with 11 queries
[Output: 78.75 Kb. compressed to 68.19 Kb. by saving 10.56 Kb. (13.41%)]
