Old July 18th, 2018, 06:08   #1
Jettamazda
TDI(s): 06 jetta
Default A/C panel no power
iv looked thru the treads and cant find anyone talking about the same problem.
I added subs to my car the other week, had the power wire on the fuse block on the battery wire nut. well it didnt really like that so i moved it to the battery. i dropped the nut and it went under the battery of course so i had to pull the battery out to get it. ever since my A/C control panel has not worked. the fan works but thats it. no A/c, heated seats,fresh air, or defrost. its to damn hot to not have A/C lol
i have googled and checked the 3 fuses that do something with a/c and they are good. i was told to check the relay 109 (i think it was) but not sure where its at to check it.
anyone know what i need to look for? where to start?
Jettamazda is offline   Reply With Quote
Old July 18th, 2018, 07:02   #2
relumalutan
relumalutan's Avatar
The best thing to do is scan the car with VCDS. I would also check all the fuses in the car.
relumalutan is offline   Reply With Quote
Old July 18th, 2018, 07:58   #3
Jettamazda
TDI(s): 06 jetta
i have checked all the fuses on the side of the dash and under the hood. all good. i will have to find me someone with a vcds or take it to a shop
Old September 30th, 2019, 11:57   #4
K7LON
Default What was the end results?
My 2006 is doing the same thing. If you can let me know what happen to yours?
Thank you
16 Ram 1500 ecodeisel
06 Jetta silver TDI, DGS,
06 Jetta blue TDI, DGS
96 2dr Metro 170k parked
K7LON is offline   Reply With Quote
Golf / Jetta Mk 4 Door Driver Side Master Panel Power Window Switch 1J3959857 chippie Private TDI Items for Sale/Wanted 1 March 11th, 2014 20:01
WTB:2001 Golf Drivers side Quarter Panel, rocker panel, MK4 black floor mats chad3ball Private TDI Items for Sale/Wanted 2 May 25th, 2012 16:58
Red Mkiv jetta/golf5 front driver power door w/ gray panel: $270 + ship OR part out Redneck Truck Private TDI Items for Sale/Wanted 1 October 4th, 2009 22:46
Help w/running aux power off fuse panel? Tristan TDI 101 3 May 24th, 2004 15:03
Stock panel or PiperX panel filter? VWBoost TDI Power Enhancements 3 February 15th, 2001 21:52
Page generated in 0.14127 seconds with 11 queries
[Output: 63.49 Kb. compressed to 56.90 Kb. by saving 6.59 Kb. (10.38%)]
