Old December 9th, 2015, 21:14   #1
siik
TDI(s): gas for now
Default Non 505.1 oil on pd (bew)
Hi,
I want to know if someone on the forum had good results with the Chevron Delo 400 LE Synthetic 5W-40 and Mobil Delvac 1 ESP 0W-40 on pd (bew) engine for about 8-16k km (5-10k miles) oci.
I live in the north coast were temp reach -40 sometimes and far from the stealer but close to a truck garage who have these oils on shelf.
If the answer is yes, I'll do an UOA from Blackstone or if there is cheaper UOA in Canada (Quebec) it could be great to know.
Best regards,
Martin
siik is offline   Reply With Quote
Old December 13th, 2015, 15:59   #2
turbovan+tdi
turbovan+tdi's Avatar
Non 505 oil will accelerate the wear on an already weak cam, don't risk it.
Old December 13th, 2015, 17:53   #3
martin33100
TDI(s): VW T5 2.5
Quite a few people are now using non 505.01 oils in there PD's with good results, Mobil Delvac and Shell Rotella being the most common.
For reference this is what the VW recomended oil did to my followers:-
martin33100 is offline   Reply With Quote
Old December 13th, 2015, 18:07   #4
n1das
n1das's Avatar
Fuel Economy: Who cares? It's a DIESEL! Great fuel economy comes as a bonus!
Exclamation
FWIW all oils are non-505.1 as there are no 505.1 oils. 505.01 is what you need.
Among the 505.01 rated oils available, the xW-40 505.01 oils have shown to provide better protection than xW-30 505.01 oils. Make sure that whatever 505.01 spec oil used is a 5W-40 oil.
Good luck and Welcome to TDIclub.
Why DIESEL is better: (Courtesy TDIclub forum member wxman)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
n1das is offline   Reply With Quote
Old December 15th, 2015, 09:27   #5
PGM jetta
TDI(s): 05 Jetta BEW
This is an old myth. Some make it forever on 505 oils and some don't see 100K before cam wear needs addressing.
Many have been using Mobil TDT or Mobil Delvac and Rotella T6(what I use) with no harm done at all. Just be sure it's a 5w-40 synthetic for diesels
PGM jetta is offline   Reply With Quote
Old December 15th, 2015, 09:50   #6
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
IMHO this is the key for PD owners, and what I follow with our V10. The first owner fed it 5w40 505.01 oil, and I use Mobil 1 TDT 5w40.
-J
Present:
2018 Tesla Model 3 DM. 20,000 miles.
2014 Cadillac ELR. 34,000 miles.
2013 Fiat 500e. 28,000 miles.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old December 19th, 2015, 13:51   #7
siik
TDI(s): gas for now
Nobody use Chevron Delo 400 5w40?
Old December 19th, 2015, 14:47   #8
scooperhsd
If the Delo 400 5w40 is a Synthetic Diesel rated oil, it will probably be OK, but as you said - not as much usage as the more popular Rotella T6 or Mobil 1 TDT .
2000 Red NB TDI, 370,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old December 19th, 2015, 17:29   #9
mountain-valleymotors
mountain-valleymotors's Avatar
Fuel Economy: 45
Delo 400 5w40 oil is a very good oil. I personally wouldn't use any non 505.01 spec oil in a PD engine, but if you are going to use one the Chevron oil is every bit as good as Rotella T6
2005 Passat Wagon TDI 5 Speed Swap and Lowered
2013 Passat TDI 6spd Manual, Night Blue, Moonrock, Fog Lights, 3M Clear Bra, Chrome SEL door trim, Splash guards.
www.malonetuning.com Dealer
mountain-valleymotors is offline   Reply With Quote
Old December 19th, 2015, 17:54   #10
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
And like T6 its only a few rungs lower on the ladder than Mobil Delvac 1.
2015 Golf SEL. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old December 19th, 2015, 20:37   #11
siik
TDI(s): gas for now
Bought a 5l of Shell Rotella T6 on sale at canadian tire for 40$CAD... Will try Delo 400 next time, I think I have it for 32-36CAD$.
Also, I can't find Mobil 1 in 5W-40 only found Mobil 1 Delvac esp 0W-40 for 47$CAD.
Pictures of the back of the Chevron Delo Le 400 :
Old December 20th, 2015, 05:57   #12
siik
TDI(s): gas for now
By the way, I've found some interesting numbers on 540ratblog :
https://540ratblog.wordpress.com/201...-test-ranking/
105. 5W40 MOBIL 1 TURBO DIESEL TRUCK synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4 and ACEA E7 = 74,312 psi
zinc = 1211 ppm
phos = 1168 ppm
moly = 2 ppm
125. 5W40 CHEVRON DELO 400LE Diesel Oil synthetic, API CJ-4, CI-4 Plus, CI-4, SL, SM = 69,631 psi
zinc = TBD
phos = TBD
moly = TBD
134. 5W40 SHELL ROTELLA T6 Diesel Oil, synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4, SM, SL = 67,804 psi
zinc = TBD
phos = TBD
moly = TBD
Old December 20th, 2015, 06:04   #13
d2305
We never did find out what the 01 specification was. All 5W40 oils are synthetic and most likely will work on the PD engine.
d2305 is offline   Reply With Quote
Old December 27th, 2015, 15:41   #14
siik
TDI(s): gas for now
134. 5W40 Liqui Moly Leichtlauf High Tech Oil, synthetic = 69,580 psi
zinc = TBD
phos = TBD
moly = TBD
This oil is made in Germany and is available in the U. S. It comes in 1 Liter bottles which is slightly more than a quart.
( Rank number change each time he add an oil test but look at the psi numbers... It's almost the same as chevron delo 400. )
Old December 28th, 2015, 06:38   #15
compu_85
Gadget Guy
compu_85's Avatar
505.01 exists to provide more protection of the PD camshaft (but not enough it seems - remember there are conventional oils that meet the older 505.00 standard which has existed since at least the early 90s) and to reduce emissions / catalyst poisoning.
-J
Present:
Past:
PD oil according to 505.01 jaredplr Fuels & Lubricants 23 January 31st, 2011 17:36
2005 TDI BEW Engine 505.00 vs. 505.01 Oil sonar23 TDI 101 1 July 18th, 2009 20:26
FS: ELF DID 5W-40 505.01 oil / PD oil spool time Private TDI Items for Sale/Wanted 9 June 12th, 2006 10:19
So the PD's use 505.1 oil... So 507 is even better for it? Braga_Dub Fuels & Lubricants 24 May 14th, 2006 14:30
Dealer using 505.00 oil in PD requiring 505.01 Alex_Scheler Fuels & Lubricants 4 December 24th, 2003 13:03
Page generated in 0.21049 seconds with 11 queries
[Output: 130.09 Kb. compressed to 108.99 Kb. by saving 21.11 Kb. (16.22%)]
