Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old January 13th, 2016, 08:05   #46
2004PassatTDI
2004PassatTDI's Avatar
2004 Passat - I have owned the car since new. Flew to a dealership on the coast of N.C. and drove it home to Chicago. Car now has 176,000 miles and runs very well. Both a deer and a texter kissed the car, but nothing that couldn't be repaired by replacing sheet metal. I don't drive it when there is salt on the street, which has spared the undercarriage. Hope I can get another 12 years and 176,000 miles out of her.
2004 Passat - 985.4 MAX Miles on 1 Vented Tank. Eibach Lowering Springs, Bilstein HD, Neuspeed RSB, RC2, www.speedhut.com boost gauge. Zender Rear Lip Spoiler, Balance Shaft upgrade, CAT back, Hot air delete, LED interior lights.
2016 E250 - Stock
2004PassatTDI is offline   Reply With Quote
Old January 19th, 2016, 07:47   #47
pkhoury
That guy with the goats
pkhoury's Avatar
153K on my '10 JSW. Just had my new turbo (the larger CR170) installed at 150K.
2010 Jetta Sportwagen - Malone DSG tune, Malone Stage 3.5, CR170, buzzken 3" straight pipe(resonator deleted), PolarFIS, Panzer plate, front and rear fogs, Bosal towhitch, Bilstein B8/Neuspeed 28mm swaybar, 2micron CP3 upgrade kit
2004 Golf GLS 5MT -
Malone Stage 4, VNT17, DC Stage 2 clutch, buzzken 2.5" straight pipe, MFA cluster swap, dieselgeek Panzer plate and short shifter, Bosal towbar, Tekonsha P3 brake controller, Hopkins short-proof trailer light converter, darkside SMIC, intake manifold, and tip pipe, PD150 airbox
2005 Jetta Wagon GLS (mom's car) - Malone Stage 4, VNT17, MFA cluster swap, Panzer Plate, buzzken 2.5" straight pipe, darkside SMIC
2015 Golf Sportwagen TDI (mom's car) - stock for now...
Other diesels:
Ford 5900 tractor
Ford 3400 Industrial tractor
2016 Mahindra XTV (1L Kohler diesel)
pkhoury is offline   Reply With Quote
Old January 19th, 2016, 07:51   #48
onykid978
14,000 since August of last year. 15 golf TDI bought it new.
onykid978 is offline   Reply With Quote
Old January 28th, 2016, 18:22   #49
Dimitri16V
Dimitri16V's Avatar
399,100 miles on my 2004 Golf BEW
2 turbos and 2 camshafts
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old January 31st, 2016, 06:32   #50
SaxmanKana
Way to go, keep it out of the Winter road chemicals if you can. Car guys here in NE Ohio are saying the stuff used on the roads is worse than salt & eats thru the corrosive barriers put on the cars at the factory.
I am driving year round, wash often in a heated garage, radiant floor heat, & use a small electric pressure washer. It helps! Also oil the car myself!
Great news on the number of miles you're getting on your TDI's. I will be doing the same, by Summer for sure!
Thanks,
Dave
Dweisel's Diesel. Thanks for reaching out to me & selling one of the herd!🐞
SaxmanKana is offline   Reply With Quote
Old January 31st, 2016, 06:47   #51
95vwgti
I'm at 171000 on my 2010 Jetta.
95vwgti is offline   Reply With Quote
Old February 6th, 2016, 16:49   #52
SaxmanKana
Is 500K expected out of these cars usually? Do Jetta's & Golf's do better than Beetles?
Thanks,
Dave
Old February 6th, 2016, 18:38   #53
djmiller
djmiller's Avatar
Fuel Economy: 40-43
05 jetta BEW, 405,807 miles. 1 turbo, 2 clutches(one was a spring failure, not a wear problem) Head gskt replaced at 400,000 miles
David Miller, LaGrange, IN. 2005 Jetta TDI KERMA Q-loader, S-7 turbo, South Bend stage 2 clutch, 43-44 mpg, 35,000+ miles per year, Admissions Rep..University of Northwestern Ohio. Do my own repairs/maintenance. Have VAG-COM & T-belt tools & Bentley manual.
www.unoh.edu
djmiller is offline   Reply With Quote
Old February 6th, 2016, 19:56   #54
ottomatic
48K in 17 months
15 GSW SE TDI 6M Reflex Silver
ottomatic is offline   Reply With Quote
Old February 8th, 2016, 12:17   #55
2015vwgolfdiesel
2015vwgolfdiesel's Avatar
Fuel Economy: City mid 40s ~ Road mid 50s ~ Two (2) 61 MPG fill ups
Newby here
APPROX ~`~` 1,700 miles on my 2015 golf S diesel ~`~` Great MPG
First VW Golf was a Silver GSL 2003 gasser 5 manual
sold it with 72,xxx miles on it
I miss this car, but do NOT miss the 5 manual
2015vwgolfdiesel is offline   Reply With Quote
Old February 8th, 2016, 17:05   #56
SaxmanKana
What's wrong w the manual, just don't like driving stick?
Old October 18th, 2018, 09:04   #57
b757236
Update 2011 TDI JSW: 288,000 miles. Fuelly 40.9mpg, original clutch STILL!
b757236 is offline   Reply With Quote
Old October 18th, 2018, 13:14   #58
Rob Mayercik
Will turn 371,000 miles tonight on my '02.
2002 Jetta GLS TDI Automatic
Baltic Green/Beige Leather
Rob Mayercik is online now   Reply With Quote
Old October 18th, 2018, 14:06   #59
SaxmanKana
248K on mine, how long does the original clutch last?
Old October 18th, 2018, 14:13   #60
tdi54
206500 miles, Turbo--user caused incident-- and the clutch changed, but still on the original brake pads. Great car to own/drive.
tdi54 is online now   Reply With Quote
Tell Us About Your Running Swaps: Mileage Racked Up,Impressions,Things You Would.... G60ING TDI Conversions 66 August 4th, 2017 17:08
Highway Miles vs. City Miles/EGR System Question lawnarjax VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 April 24th, 2015 09:59
2002 Jetta TDI 5speed 230k miles Selling my 2002 TDI with 230k miles 5 SPEED manual t VDUBjettaTDI TDI Cars for Sale/Wanted 10 September 16th, 2013 15:59
2009 TDI Jetta with 6900 miles. 53.1 mpg, 2600 miles. Rod Bearing TDI Fuel Economy 4 December 15th, 2008 14:02
98 A3 Jetta with Only 9,044 miles, Yes, 9K miles. Harvieux TDI Cars for Sale/Wanted 2 March 9th, 2003 19:19
Page generated in 0.20232 seconds with 11 queries
[Output: 126.04 Kb. compressed to 105.06 Kb. by saving 20.97 Kb. (16.64%)]
