Old September 9th, 2015, 12:11   #31
will24
Just bought an 05.5, currently has 227k on it.
PO did clutch and trans at 180k
All wheel bearings at 222k
Cam has NOT been replaced
I haven't gotten it home yet, but will keep everyone posted
ASE Master Certified Medium/Heavy Truck tech, with L2, and A9
05.5 Jetta TDI 5 speed Reflex Silver (265k)
05.5 Jetta TDI 5 speed Platinum Gray (131k)
will24 is offline   Reply With Quote
Old September 9th, 2015, 16:59   #32
jjtoutt
jjtoutt's Avatar
Jeez, my 06 only has just over 100,000 miles
2006 jetta TDI/Colt stage 2 cam/GTB1749/PD150 injectors/Malone stage 5 with EGR delete/BuzzKen turbo-back/H&R coilovers
jjtoutt is offline   Reply With Quote
Old September 9th, 2015, 22:38   #33
Kyosho618
I have a 2005.5 MKV BRM PKG 1 (Love the beast!)
Mileage: 227,000 (my daily)
Avg mileage: 550-600 miles
This car has almost everything original, turbo, cam, lifters. Only thing replaced was Egr cooler which was leaking last year.
I did end up putting a vr6 clutch w/g60 flywheel in it today (original dmf was ****)
Other than that, German engineering really holds together well!
Can't wait to tune it next!
These cars have a lot of potential, I'm excited! 😁
Kyosho618 is offline   Reply With Quote
Old September 9th, 2015, 22:43   #34
BRMTDI
Tune really wakes these things up
BRMTDI is offline   Reply With Quote
Old September 11th, 2015, 06:31   #35
stennyboy
stennyboy's Avatar
TDI(s): 06 Jetta
Just hit 200k, 06, 5 speed, doesn't use any oil.
Cam at 160k
EGR deleted at 160k
stennyboy is offline   Reply With Quote
Old September 21st, 2015, 20:27   #36
tdi_guest
I'm the original owner of mine which still has under 95,000 miles. And it had a new DSG put in at ~57K after the flywheel broke apart and tore up the transmission. Maybe this is the wrong thread for me!
2003 VW Jetta GLS TDI wagon, auto, monsoon, reflex silver - totalled
2006 VW Jetta TDI, DSG, pkg#1, rear-side airbags, black
tdi_guest is offline   Reply With Quote
Old September 22nd, 2015, 18:28   #37
jayp111
TDI(s): n/a
Fuel Economy: n/a
Only 290k
"All that is necessary for the triumph of evil is that good men do nothing." (Edmund Burke)
Never underestimate the power of stupid people in large groups...
"Political Correctness is a doctrine, fostered by a delusional, illogical, liberal minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
VAG Com
jayp111 is offline   Reply With Quote
Old September 22nd, 2015, 19:50   #38
FjShaffer
TDI(s): 06 Jetta TDI
Default Mk v brm
'06 Jetta 270,000 original everything except wheel bearings (too many to count) and one timing belt and water pump. I just ordered a camshaft rebuild kit OEM. Now, I hope that cures the smoke and hesitation issue at acceleration.
FjShaffer is offline   Reply With Quote
Old September 22nd, 2015, 19:57   #39
325isbimmer
325isbimmer's Avatar
I have 350,000km on my BRM with similar maintenance history.
For me the hesitation was solved by the VNT stop set screw adjustment aka zip tie mod. I just actually adjusted my set screw as per a thread here?
Sent from my iPad using Tapatalk
2006 Jetta TDI Highline | Reflex Silver/Black leather
Colt Cam Stage 1 | Malone Tuning Stage 1 & 2
SMF 21lb Flywheel | G60 clutch | "Dogbone" Mount Insert
GLI 312mm Slotted Rotors | EBC RedStuff pads F&R
325isbimmer is offline   Reply With Quote
Old September 22nd, 2015, 20:01   #40
FjShaffer
good to know so I wont get depressed if the camshaft doesn't solve the issue.
Old September 23rd, 2015, 13:45   #41
rammd
TDI(s): 2005.5
I have a 2005.5 jetta with a BRM. It has 320k on it now. Replaced the turbo and cam shaft at 300k. The tops of the lifters where wearing through, one lobe was wearing down as a result. Clutch was replaced at 270K nothing else done except the standard timing belts and water pump changes. It burns no oil and averages 50mpg on a 25 mile highway commute. I'm hoping to make it to 450k.
rammd is offline   Reply With Quote
Old September 23rd, 2015, 14:00   #42
ITDID
ITDID's Avatar
Fuel Economy: 40's over hill and dale
Mine has 262000 miles
Cam: 1 @175000
DMf: 1 @ 77,000
Wheel brgs all around: 180-250k miles
Struts and shocks at 250
Alt and pulley: at 210k
Dsg: new at 77000 (killed when the DMf grenaded at hwy speed)
Body is fair with all that craptastic salt in the wintertime could be a LOT worse if it were a mazda!
Mpg's in the low 40's in the hills of the finger lakes of NYS.
ITDID is offline   Reply With Quote
Old September 28th, 2015, 17:01   #43
Mach1
Fuel Economy: 49.3, 48, 21.2,19.99
There was a member on here that had 600000m on his chase/escort vehicle..I tried to buy it from him..he had these over 3 years ago..his maint. records were..5 timing belts, couple drive axles, over a hundred oil changes..1 cam and lifters i believe..he let it run during lunch..started car in morning and left it idle at lunch..ran 12 hours a day..
These cars are bullet proof, have there querks for the factory, but get 50mpg, run hundreds of thousands of miles..
I still own my 2..the dsg hass 190000m..the 2005.5 modified 5 speed has 125000m...
I am keeping them forever and still love them..You cant buy a car like this anymore..
2018 F150 3.5 ECO 3.55 10spd 20s 2tone 26mpg 2turb
2006.5 DE DSG, RC2, Sunroof, 200K miles, 61MPG best
2005.5 Jetta-5 SP LSD Spec S2 130K ELF506 10-30W OCI=20k ORIGINAL CAM RSB Diesel custom 2.5DP/3" SS Pkg 1 Auto-dim mirror auto-WW auto-climate 248tq=150HP RC2 lowered 312 brakes
Mach1 is offline   Reply With Quote
Old September 28th, 2015, 18:57   #44
narongc73
Originally Posted by Windjammer View Post
I don't know how that's possible but wow. Pretty cool
Mostly hwy driving will do that.
narongc73 is offline   Reply With Quote
Old September 29th, 2015, 12:52   #45
flyingnut40
Default My 2006 BRM
I have a 06 Jetta with about 680,000 KM or about 420,000 Mi. to you folks that don't do metric well..... and just to confuse you more this mornings 75 mile commute into Toronto in highway and commuter stop and go I got 63 MPG (Imperial gallon - 4.54 litres) your American gallon is 3.9L.
Haven't read the whole post, is anyone higher than this?
2006 Jetta BRM DSG Leather 2 package with nav. Loaded. Been agreat car overall.....
Dennis
flyingnut40 is offline   Reply With Quote
06 brm jetta. High mileage. 38326. Middle tn ondwater TDI Cars for Sale/Wanted 3 August 26th, 2014 03:25
06 Jetta BRM high altitude issues kdawg89 VW MKV-A5 Golf/Jettas 1 April 23rd, 2014 18:18
New TDI owner. 06 Jetta (auto) high mileage Created VW MKV-A5 Golf/Jettas 5 April 3rd, 2013 06:48
Buy a high mileage 06 jetta? vwcruisn VW MKV-A5 Golf/Jettas 18 August 28th, 2010 15:20
Popular High Mileage contest - Under 200K need not apply ICNTDRV TDI 101 20 August 8th, 2006 22:13
Page generated in 0.18666 seconds with 11 queries
[Output: 124.91 Kb. compressed to 104.29 Kb. by saving 20.62 Kb. (16.51%)]
