Old November 19th, 2014, 12:46   #1
TSPowll
TDI(s): 2009 Jetta
Default 2009 TDi glow plug connector broke
I'm in the middle of trying to figure out a P13D1 code, which I've attempted to solve by swapping glow plugs. This did't work, still same code for same cylinder.
Anyways, in the process of moving glow plugs I broke the very bottom of a connector. It is a plastic ring that snaps on the bottom of the connector. It doesn't have a VW part number so the dealership cant get it. They are trying to sell me an entire harness that cost several hundred dollars because this stupid little plastic part broke. I've tried every local junk yard and VW repair shops with no luck. So I'm now looking for help from you guys. If anyone has replaced this harness and no longer needs this part, would you be willing to sell it to me?? Or do you know where I can get it??? I'm assuming this part is the same on all 2.0L TDi engines so the Passat and other cars may work.
In the picture you can see the part on the left is missing.
TSPowll is offline   Reply With Quote
Old November 20th, 2014, 14:52   #2
TSPowll
TDI(s): 2009 Jetta
Finding this little piece of plastic has got to be one of the hardest things I've done. I have spent countless hours on the phone with dealerships, repair shops and junk yards with no luck. Out of the 8 dealerships I have talked to, more than half have been completly less than helpful.
One dealership, instead of trying to sell me the ENTIRE harness, did find a harness repair kit. Part# 03L971785A It's basically one connector and enought wiring to go all the way to the ECM. This is the closest I've come so far. Price is just under $60 from the dealership, and the cheapest is $40 from ECS Tuning (with shipping almost $55).
At least I've found a cheaper option than the entire harness, but im not willing to give in and pay that much for such a small part.... So the search continues.
Please help or chime in if you have any leads.....
Old November 20th, 2014, 16:20   #3
yatzee
yatzee's Avatar
TDI(s): see sig
a scrap yard might be helpful
2015 Passat TDi 6 spd, 2008 WK CRD, 1991 405 mi16, 1986 and 1987 190e 2.3-16
yatzee is offline   Reply With Quote
Old November 20th, 2014, 16:34   #4
TSPowll
TDI(s): 2009 Jetta
I've talked to about 8 different scrap yards, including a VW specialized one out of California. No luck. I was really hoping a member on here has changed out a harness and has one lying around.
Old November 20th, 2014, 17:29   #5
N2UADTDI
Do you have the ring that broke off? It looks like the ring snaps onto the connector.
Do you have access to a 3d printer and CAD software? Something that small would be difficult to print on a 3d printer but it may be worth a shot.
N2UADTDI is offline   Reply With Quote
Old November 20th, 2014, 20:48   #6
TSPowll
TDI(s): 2009 Jetta
The ring that broke off was still stuck on the glow plug. Since the tabs on it were destroyed I just broke it up more to get it off the glow plug and used compressed air to get the pieces out of the hole. So no, I don't have the piece per say.
Old November 24th, 2014, 16:53   #7
TSPowll
TDI(s): 2009 Jetta
Finally found one... Thanks to Andrew(2micron) who is sending me one from a used harness that he had. Thanks Andrew!!
Old October 1st, 2019, 16:40   #8
Coastiedeneke
TDI(s): 2009 jetta
Default Also looking for this part
Hello all I am also looking for two of these clips. If anyone can steer me in the right direction I would appreciate it.
Coastiedeneke is offline   Reply With Quote
Old October 2nd, 2019, 06:10   #9
N2UADTDI
You can carefully glue the 2 parts of the connector back together. Use a thick consistency crazy glue. If the bottom part of the connector is still on the glow plug, you can pull it off with a hooked tool.
Old October 2nd, 2019, 16:08   #10
Coastiedeneke
TDI(s): 2009 jetta
Default Cover
Hello thank you for the reply but unfortunately the cover fell apart in several different pieces and canít not be glued together
Coolant Glow Plug connector ?? JettaDrvr TDI 101 9 April 11th, 2017 01:00
Glow Plug Connector JettaBlue VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 November 7th, 2013 17:13
Glow plug connector replacement igiveup VW B5 Passat TDIs 1 July 27th, 2013 21:35
98 vw jetta tdi glow plug broke off wickd_1 TDI 101 1 January 28th, 2012 06:39
Glow plug broke in cylinder head below the threads on AHU TDI Diesel Fumes TDI 101 48 February 6th, 2009 20:50
Page generated in 0.16833 seconds with 11 queries
[Output: 92.44 Kb. compressed to 78.45 Kb. by saving 14.00 Kb. (15.14%)]
