Old January 20th, 2012, 18:03   #1
tdiatlast
Default 2012 Passat TDI: "Crack" sound behind dash
We've now heard a nasty "crack" sound 3 different times, coming from behind the dash, at the base of the windshield.
Each occurance was while accelerating or decelerating (I guess "loaded" drivetrain?), going over a large expansion crack. The sound occured simultaneously with the tires smacking the crack in the road.
The first time it happened, everyone in the car freaked (my wife asked if I had hit something), as it sounded like a stick had fallen near the windsheild.
There are no other indications of a problem...no rattles/vibrations of any kind.
Any thoughts? Is the possible the dash is improperly installed? I'm really baffled by this one.
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2017 Ford Energi Titanium, purchased 12/15/18
tdiatlast is offline   Reply With Quote
Old January 22nd, 2012, 18:34   #2
TomB
Fuel Economy: 34 mpg on first tank
I think you may be hearing the steering assist. I did a hard acceleration and the traction control kicked in as well as the brakes or anti lock brakes, not sure what all and heard a sound like this.
I read something about the traction control features and that the steering is now controlled as part of this as well. It was in the manual in the section about traction control, something about the DSP Plus system or something new like that.
2007 Jeep Grand Cherokee 3.0L MB Diesel
2012 Passat TDI SEL Premium Opera Red/Titan Black
2015 Audi A3 TDI Prestige S-line Lotus Gray Metallic/Black Leather
TomB is offline   Reply With Quote
Old January 22nd, 2012, 23:41   #3
TomB
I am wondering about a sound I heard tonight. Under a full throttle start on a slightly wet surface, the car took off crossed the painted intersection/crosswalk lines and then the ESC or some other system kicked in and cut power.
Then the engine kicked in again and there were several large clunk sounds that sounded like the old days with rear wheel drive on high HP cars and the bars attached to the axle would hit the frame (I cannot remember the right name for them).
They had rubber on the one end and were supposed to contain the rotation of the axle from all the torque.
Is this a thing associated with transverse mount versus longitudinal mounted engines? The motor mounts giving way? Torque protection bars?
Anyone know?
Old January 23rd, 2012, 05:44   #4
tdiatlast
This doesn't sound like a suspension clunk. It sounded more like plastic getting hit with a hammer, maybe like the dash assembly not being properly secured to the "firewall." (Don't know why I put "firewall" in quotes...with th DPF getting upwards of 1300f, the term is once again very appropriate!)
Sadly, in order to duplicate it again, I have to abuse the car and find a pothole to smack...
Old January 23rd, 2012, 15:00   #5
TheGrove
Anyone know?
Don't know but mine did the same thing last week when I accelerated too hard on some wet pavement. Scared the heck out of me. Made me very quickly back out and put less foot into the throttle.
2012 Passat SEL Premium TDi Opera Red - Dieselgate Fix, KermaTDI Tune
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old January 23rd, 2012, 15:05   #6
tdiatlast
Hmmm... I think I know what traction control sounds like, but maybe not. My sound doesn't match that.
I'll say again, in every case for me, the "crack" was quick, percussive, and like a hammer hitting plastic. The sound occured when hitting an expansion crack, square on, both tires at the same moment.
Old January 23rd, 2012, 15:08   #7
abctdi
abctdi's Avatar
Slapper bars, or traction bars...
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old July 24th, 2012, 17:20   #8
tdiatlast
OP here. My car is an early production (5/2011). While at the dealer today for its state safety inspection, I decided to check out the dash integrity of other production Passats.
In my car, if I grab and gently push/pull the dash where it arches above the steering wheel, I can hear the dash creaking/rubbing against the Fender trim piece that runs along the dash at the base of the windshield. It doesn't sound loose, but definitely is creaking/binding.
The 2 new Passats I checked did NOT make any sound when I tried to make the dash shift.
The dealer has offered to install a sound deadening kit, which he said is simply strips of foam tape between the 2 dash components. This would require some disassembly of the dash, which I'm not very happy about.
Can anyone tell me how the trim at the base of the windshield attaches to the main dashboard? How complicated is it to remove, so some foam tape can be placed between it and the dash?
Thanks. I continue to be VERY impressed with the service I'm getting at Stohlman VW (Jack Smith, service advisor) as they're very attentive to my requests.
Old July 24th, 2012, 18:36   #9
Good Ol' Boy
VeeDubTDI's Avatar
I'd go ahead and have them install the kit.
Old July 29th, 2012, 21:16   #10
Rajpatel1969
Heard this creak or crack but mine came from the fender speaker raised bar just in front of the windshield. If you press down on his bar on one side, you might be able to recreate it. It's a hard plastic creak noise.
Rajpatel1969 is offline   Reply With Quote
Old July 29th, 2012, 21:52   #11
tdiatlast
Raj, that's where the noise is coming from (see post #8 above), where the Fender trim contacts the main dash. Dealer has offered to add foam tape between the two parts.
Old July 31st, 2012, 18:13   #12
Rajpatel1969
Mine is a April 2012 production car. Guess it's still being unresolved. What is the scope of effort to fix it? Foam tape by removing dash? Forget it.
Old August 1st, 2012, 14:08   #13
eatpasta
eatpasta's Avatar
TDI(s): 2012 Passat
I get that sound too when I turn on the AC in the heat....the sound of the dash shrinking slightly with the cold air.
We shall not cease from exploration, and the end of all our exploring will be to arrive where we started and know the place for the first time.
T. S. Eliot
eatpasta is offline   Reply With Quote
Old August 1st, 2012, 19:23   #14
tdiatlast
That's my question. How difficult is it to remove the dash trim below the windshield? If it's a "no-brainer", I'll do it myself. However, if it requires major dis-assembly of the entire dash, I'll probably just learn to ignore the sound.
When I return home from our vacation, I'll probably experiment with bits of foam tape and a plastic "trim" tool. I'll try to push small strips of foam tape between the dash trim and the dash itself.
Old August 2nd, 2012, 08:31   #15
JARED_LA
I'm having the same issues. I think you can pop the fender piece out. I tried this morning before leaving work and was able to pry the ends up where the Fender label is. Simply push up with your thumb.
JARED_LA is offline   Reply With Quote
2012 dash "convenience menu"? G_Monee VW MKVI-A6 Jetta Sedan (~ 2011+) 1 January 12th, 2012 06:49
"Adjustable, Intermittent Wipers" on 2012 Passat TDI? physicshogon Upgrades (non TDI Engine related) 3 December 2nd, 2011 05:05
"Adjustable, Intermittent Wipers" on 2012 Passat TDI? physicshogon VW Passat Family (NMS and B7) TDIs (2012+) 3 December 1st, 2011 17:35
"Adjustable, Intermittent Wipers" on 2012 Passat TDI? physicshogon VW Passat Family (NMS and B7) TDIs (2012+) 0 December 1st, 2011 15:06
Apparently the 2012 Golf TDI will now have "Seattle" Alloys instead of "Salamanca"? TDInewbee VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 3 July 26th, 2011 13:10
Page generated in 0.20028 seconds with 11 queries
[Output: 128.76 Kb. compressed to 107.67 Kb. by saving 21.10 Kb. (16.38%)]
