Old August 21st, 2019, 19:44   #76
N2UADTDI
I need to replace the condenser on my 2009 Jetta. What type of seal is there on the connection plate? I can't seem to find it in the online parts books.
Thanks...
N2UADTDI is offline   Reply With Quote
Old October 7th, 2019, 11:31   #77
Teamzarz
TDI(s): 2009 JSW
Okay I have searched through countless threads between here and Audizine forums regarding my issue. I have a 2009 JSW.
I am getting the 00819 G65 Short to ground code.
My old senor has been replaced with this part FCP EURO - G65 Sensor - Rein
In VCDS I am getting a dash (-) where refrigerant pressure should be reading. My old sensor read 0.0 bar and I was getting the same 00819 code. I believe that sensor failed and all the refrigerant leaked through the connector which is why I replaced the sensor.
I can try clearing the code and it instantly comes back, after three or so tries to clear it It will stay cleared until I restart the car.
I have looked for wire loom issues, and I am about to check continuity to make sure there isn't some wire break in the harness.
ALso after replacement of my old switch I had the system evacuated and recharged at a shop for $80 so I know the system is sealed and charged.
I probably should have read reviews on this part since it does say in the reviews that one person received a dead unit on arrival.
Anyone else try this part and get similar results? More likely wiring issue or more likely defective unit?
Teamzarz is offline   Reply With Quote
Page generated in 0.13582 seconds with 10 queries
[Output: 50.21 Kb. compressed to 46.35 Kb. by saving 3.87 Kb. (7.70%)]
