Old September 25th, 2009, 12:49   #16
festivenuts
Fuel Economy: 40mpg
Ugh starting to get a headache with this alternator.
Any suggestions? I'm not sure if I'm clever enough to change the alternator.
Could it possibly be a malfunctioned alternator regulator. I just find it odd that I come back after 2 months and alternator just doesn't work...
I don't know where to go from here any suggestions
festivenuts is offline   Reply With Quote
Old September 25th, 2009, 13:41   #17
JB05
Fuel Economy: 43/41/40
In response to Steel's question, have a look at post #14:
http://forums.tdiclub.com/showthread...ernator+pulley
JB05 is offline   Reply With Quote
Old September 25th, 2009, 15:24   #18
festivenuts
Fuel Economy: 40mpg
yea my tdi has low idle and shakes as well (i push the pedal a bit to keep it smooth)
just picked up a 2003 120amp alternator from a bug. time to follow wingnuts guide
wish me luck!
Old September 25th, 2009, 18:03   #19
Steel
Fuel Economy: 26 mpg
Thanks JB. So basically, the rate of acceleration (and deceleration) of the crank at idle is a lot more severe than a gasoline engine hence the one way clutch? One would think that they'd one way clutch everything that isn't indexed to the crankshaft then... or use a heavier flywheel. Hmm.
Steel is offline   Reply With Quote
Old September 25th, 2009, 19:57   #20
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
90amp. alternator was update to 120amp. So if you have 90amp on your car you should update to 120amp.
Gas engine 120 has same alternator and pulley. 90 is not because it has solid pulley, but 120 has same .
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old September 27th, 2009, 21:02   #21
festivenuts
Fuel Economy: 40mpg
thanks to everyone for helping me out and steering me the right direction
thanks to wingnuts excellent write up i swapped out the broken alternator for a functioning 2003 vw bug 120 alternator
all is well now
Old October 11th, 2019, 06:44   #22
intro
Final word was that a 120 amp alternator will work on a TDI or a gasser? They are swappable either way? I see one at IDParts I'm interested in for my 2.0L AZG.
intro is offline   Reply With Quote
Old October 11th, 2019, 08:36   #23
Mongler98
Yes. Correct. However, rebuilding them is the best option. They are not difficult to rebuild with new brushes and regulator. If the stator where the brushes ride is severe worn though, more than a mm or so, then it also needs to be replaced and that's where a junkyard one is best to rebuild. There is a thread here somewhere about how to rebuild them and links to all the OEM Bosch parts.
Old October 11th, 2019, 09:45   #24
intro
Thanks, I was hoping to rebuild but the pulley turns to the left just fine when I insert a screwdriver and locks to the right, the voltage regulator looks within spec:
Not sure what else there is to rebuild or how deep I can get into things. The only thing I can think of is when I was tapping it into place I knocked something loose inside.
The service alternator light hasn't been showing in the dash, but it is there when I turn the key.
It did fail the bench test at Advance:
My thought was to order the TYC for cheaper. This Bosch didn't prove to do too well at 3 years.
Old October 11th, 2019, 16:52   #25
Mongler98
Rebuilds are garbage. Do it yourself with proper parts, will be about $40 in parts, common tools do the job, you need to solder but it's not that bad
Old October 17th, 2019, 13:30   #26
jokila
jokila's Avatar
Fuel Economy: 52/45/40
The alternators from the Audis will work too. Most of them are 120amp
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
Page generated in 0.17804 seconds with 10 queries
[Output: 97.72 Kb. compressed to 82.39 Kb. by saving 15.33 Kb. (15.69%)]
