Old September 23rd, 2009, 15:51   #1
festivenuts
Fuel Economy: 40mpg
Default TDI Alternator Gas Alternator Swappable?
My 1999.5 TDI alternator clunked out.
Am I able to use a Gas VW alternator from the same year?
festivenuts is offline   Reply With Quote
Old September 23rd, 2009, 16:45   #2
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
You will probably have to exchange the pulleys, but yes they are interchangeable if they are the same power rating. My guess is the gas car will only have a 90 amp, though.
-Jason
Present:
2018 Tesla Model 3 DM. 47,000 miles.
2014 Cadillac ELR. 38,000 miles.
2013 Fiat 500e. 28,000 miles.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old September 23rd, 2009, 17:09   #3
BleachedBora
BleachedBora's Avatar
Actually the pulleys are both 6-rib systems. Most of the '99s regardless of 2.0, 1.9, 1.8T or VR6 should all have 120 amp systems. If you have a 90 amp it's a rarity.
-BB
BleachedBora is offline   Reply With Quote
Old September 23rd, 2009, 19:05   #4
dogdots
dogdots's Avatar
TDI(s): None
I doubt that the pulley on the gasser is a one way clutched pulley, but I could be wrong.
Non VW: 2011 BMW 335D and 2011 BMW X5 35D, 1977 MB 280SL, 1979 Chevy C20 6 banger with 51k original miles, 1977 Chevy C10 454 bought new by wife's grandfather.
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old September 23rd, 2009, 19:39   #5
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
-BB
Wrong.
Autos were all 90 the manuals were 120.
Swap the pulley or better yet get a new one. The key is it has to have a sprague clutch in it.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old September 23rd, 2009, 19:39   #6
jasonTDI
jasonTDI's Avatar
Solid one on the gassers.
Old September 23rd, 2009, 19:41   #7
BleachedBora
You're right, momentary insanity
Still, I stand by they should all be 120a systems!
Old September 23rd, 2009, 19:45   #8
alphaseinor
I've installed many 120A alternators in 90A cars... IIRC they all should be the same
alphaseinor is offline   Reply With Quote
Old September 23rd, 2009, 19:47   #9
jasonTDI
jasonTDI's Avatar
I agree and install only 120's.
Old September 23rd, 2009, 21:13   #10
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
Me too... It doesn't make sense to put the 90 back in..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old September 25th, 2009, 10:35   #11
festivenuts
Fuel Economy: 40mpg
Am I able to install an alternator from a 2003 VW Beetle? (120 amp) In my 1999.5 golfy?
Old September 25th, 2009, 10:50   #12
Turbine Suburban
Forgot: Why does it have the clutch?
Turbine Suburban is offline   Reply With Quote
Old September 25th, 2009, 11:12   #13
festivenuts
Fuel Economy: 40mpg
could it be a screwy regulator issue?
i left for 2 months and returned to a dead battery and alternator that's not charging
Old September 25th, 2009, 11:30   #14
Steel
Fuel Economy: 26 mpg
I'm curious too as to why the TDI alternator has a one way clutch.
Steel is offline   Reply With Quote
Old September 25th, 2009, 12:07   #15
compu_85
Gadget Guy
compu_85's Avatar
To make the crankshaft pulley's life easier, and to make the alternators life easer. Go watch a gasser or early TDI... rev it up and let it return to idle, you can see the stress on the belt go the other direction for a moment.
-Jason
Present:
Past:
Page generated in 0.17584 seconds with 10 queries
[Output: 127.17 Kb. compressed to 105.72 Kb. by saving 21.45 Kb. (16.87%)]
