Old October 8th, 2019, 06:45   #76
rocketeer928
rocketeer928's Avatar
Originally Posted by oldpoopie View Post
Why donít you try that out and let us know how it works out...
LOL Not too nice oldpoopie!
I would review that timing belt link above, Lock_t.
2003 Jetta GLS TDI with RocketChip RC5-ASV-Euro tune specific to my performance modifications - Platinum Gray
yo
1970 VW Type 3 Squareback - Cobalt Blue (Birdie)
rocketeer928 is offline   Reply With Quote
Old October 8th, 2019, 10:53   #77
Lock_t
Fuel Economy: mid 40s
I mean I'll try anything once unless I find research proving it won't work. Don't think that everybody on here that asks questions doesn't do their research.
I have looked at it thanks appreciate all the wonderful insight
Lock_t is offline   Reply With Quote
Old October 8th, 2019, 12:41   #78
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Yes, we do assume a lot, or we take nothing for granted.
Originally Posted by Lock_t View Post
so swapping IPs doesn't need VC removal, do you HAVE to take cam sprocket off or even vacuum pump off? theoretically wouldn't you be able to loosen the tensioner, pull the belt, keep an eye on TDC mark on flywheel and just swap pumps being that you have the pump locked at TDC? or am i missing something crucial?
Believe what he meant to say was no, that won't work.
Old October 8th, 2019, 15:27   #79
Lock_t
Originally Posted by jimbote View Post
...i did a pump swap in his driveway 25 minutes start to finish including hammer modding the manual pump... totally uneccessary to remove the VC during a swap ... just establish tdc first and have the pump pin handy
so what's the scoop with this?
Old October 8th, 2019, 16:14   #80
flee
flee's Avatar
Fuel Economy: 40-ish
As Jim states, if the engine was timed correctly and the pin goes in then it is close to TDC.
Verify with the flywheel timing mark, of course.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old October 8th, 2019, 17:12   #81
Lock_t
right so if you can see TDC mark on flywheel through trans hole and not messing with timing other than strickly working on IP wouldn't it be somewhat of an easy swap? or am i looking at this through too much of a tight lens?
Old October 9th, 2019, 08:46   #82
jokila
jokila's Avatar
Fuel Economy: 52/45/40
That's the right thing to do but you still need to follow the part of the timing belt procedure on how to set the tensioner properly. That is why i posted the timing belt pdf for you.
You are going to need to pop the sprocket off the camshaft and then at some point torque the sprocket back on. You really want the camshaft index/lock tool to be there to ensure it stays in the correct position. The crank is easy to see whether it's in position or not.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
Old October 11th, 2019, 12:35   #83
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Speak for yourself... some of us old farts have a hard time seeing those flywheel marks...
Y.
Quando omni flunkus moritati
ymz is offline   Reply With Quote
Page generated in 0.14116 seconds with 12 queries
[Output: 88.60 Kb. compressed to 76.55 Kb. by saving 12.05 Kb. (13.60%)]
