Old September 15th, 2019, 15:25   #1
beckster
Default electrical issues - no blower motor, no wipers, no turns
so we have a 2003 golf tdi, which a few months ago, a nut came loose on 75X and melted the relays and the housing for the relays. Back then the headlights, wipers, and turns didnt work and the horn was permanently on.
we replaced the wires and relays and the housing for the relays so for a few months everything worked fine.
then during this past summer, we kept on having issues where the A/C motor resisters kept burning out, so after 3 of them we replaced the motor and resistor. everything was fine for a month.
now what doesnt work...
the blower motor doesnt come on at all, even when you switch it to fan speed 4
no turns
no wipers
what does work...
headlights, hazards, radio
did some research for a week, replaced all the relays (including load reduction relay) and the ignition switch (the end with the electrical, not where the key goes in). when we were in the steering column all of the wires looked fine. jiggling the keys didnt make a difference. checked under the dash where the relays are for loose wires, etc, everything seemed fine but not 100% sure what to look for.
hopefully someone whos more familiar with the electrical system can help. thanks
2003 Golf GLS TDI - 235k mi - stock
2003 Jetta GLS TDI - 296k mi - not stock
beckster is offline   Reply With Quote
Old September 15th, 2019, 15:36   #2
roadhard1960
Fuel Economy: 48 mpg
Fuses are good inside the car?
2003 Jetta wagon GLS, 5 Speed, Alligator tune, 34 psi tire pressure, 49.1 US mpg first 35k, 50 next 31.5k, 50.4 next 36k miles, cleaned intake twice and polished end runners last time, Mobil Truck & SUV or Delvac. Koni FSDs, VWs since 1977. Sprint 520 Nozzles for Christmas 2007. Ecodes with fogs and Eswitch. 571,000 miles and counting, original turbo. 2004 Dodge 2500 Cummins HO.
roadhard1960 is offline   Reply With Quote
Old September 15th, 2019, 15:42   #3
beckster
yes, the ones on the side of the dash, we checked pretty much all of them but if theres a specific one we should be looking at it wont hurt to double check.
Old September 15th, 2019, 17:16   #4
roadhard1960
Have you checked both sides of the fuse holder? One side should have 12 volts, or 13 volts.
Old September 15th, 2019, 18:08   #5
beckster
Will have to give that a look.
Old September 15th, 2019, 19:36   #6
wonneber
Did you check the fuses for power or just that they look good?
I would check the heavy fuses above the battery.
Check for power to the stud on both sides of the fuse.
Key on.
Check fuse 25 in the inside fuse box for power.
It's for the blower.
No headlights, no wipers and no turns dweisel VW MKIV-A4 TDIs (VE and PD) 4 March 18th, 2018 05:16
No headlights, no wipers and no turns dweisel VW MKIV-A4 TDIs (VE and PD) 7 March 13th, 2018 17:45
No headlights, turns or wipers???? dweisel Private TDI Items for Sale/Wanted 0 March 13th, 2018 08:33
Blower motor issues(not resistor) SkiBumJH VW MKV-A5 Golf/Jettas 20 July 30th, 2017 00:38
blower motor issues xltsp8 VW MKIV-A4 TDIs (VE and PD) 6 September 15th, 2014 07:52
Page generated in 0.15077 seconds with 11 queries
[Output: 74.02 Kb. compressed to 64.86 Kb. by saving 9.16 Kb. (12.38%)]
