SMF and DMF 5-Speed Clutch Kits on SALE @ IDParts.com
cevans
TDIClub Enthusiast, TDI Parts Ninja Vendor , w/Bus
Hingham, MA
2015 Beetle Conv. TDI 6-Speed & 2006 E320 CDI
Clutches on Sale!
Most TDI engines can last 500k miles or more. However, the clutch assembly typically does not. Most models were equipped with a weak dual-mass clutch that is prone to slipping and flywheel failure. Cold weather brings out any clutch problems, and you might have experienced some clutch slip when the temperature dropped this year.
We've got BRAND NEW clutch set ups on sale starting at just $199! This LUK Dual-Mass Flywheel & Clutch Kit uses an upgraded flywheel design along with a stronger clutch-pressure plate assembly. With a buttery-smooth pedal, this is THE BEST choice for stock or mild-tuned 5-speed TDIs.
If you are in the market for a Single-Mass conversion upgrade, our SMF conversion kits start at just $329! Single-mass flywheels are rock-solid reliable, and the "Quiet" design by Sachs limits in-gear rattle to a minimum.
If you have 300k+ miles on your TDI, we have Complete Clutch Kits that are specially made to address all the common wear items on high mileage cars.
6-Speed Kits On Sale Too!
Bought-back & fixed TDIs should be available on the used market soon, so we are continuing to stock great 6-speed clutch kit options. We have 6-speed SMF Conversion Kits from Valeo on sale, plus upgrade options from South Bend Clutch. We also have Dual-mass kits using OE components!
cevans
Hingham, MA
Clutch sale ends Sunday!
cevans
Hingham, MA
Sale has ended. Thanks everyone. Mods please lock.
