Jens590
I started the car a few mins before leaving work today walked away and came back 5 min later and the car was making this noise like a crankshaft knock or a broken motor mount but it goes away when you step on the loud pedal and start driving the car and everything seems normal again. when you slow down, push in the clutch and stop it does this weird transition where it feels like i have stock motor mounts for a sec then the knocking sound/feeling comes back. also there are no trouble lights and the no abnormal smoking and the boost gauge reads normal, loading/unloading of the turbo feels normal im competely baffled and my next move is taking the oil pan off to check the bottom end
the car is modified it has an 034 solid dogbone with VF upper mounts i dont think they are the problem i checked them out and nothing looks or moves like its broken
