Old August 27th, 2015, 19:50   #1
jjcsnlynn
jjcsnlynn's Avatar
Default Ventectomy Pics
I want to perform the ventectomy but there used to be a thread with pictures. I can't find it anywhere. Even the one in TDI 101 doesn't have pictures.
Does anyone have a link to one?
02 Jetta TDI (5-Speed)
03 Jetta TDI (5-Spd Wife's)
96 Passat TDI (5-Speed Son's)
04 2500 HD Duramax Diesel 4x4
jjcsnlynn is offline   Reply With Quote
Old August 27th, 2015, 20:19   #2
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
YouTube:https://m.youtube.com/watch?v=If0z8UnIZkc
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is offline   Reply With Quote
Old August 27th, 2015, 20:45   #3
deejaaa
deejaaa's Avatar
Fuel Economy: JETTA IS FOR SALE!
http://pics.tdiclub.com/gwillie/VW/ventectomy/
THE 2002 jetta IS for sale. PM FOR DETAILS.
deejaaa is offline   Reply With Quote
Old August 28th, 2015, 06:43   #4
belome
Fuel Economy: 47'ish
I just hit the button with the end of the pump nozzle. Get the same effect without having to tear into the car.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old August 28th, 2015, 06:48   #5
LNXGUY
LNXGUY's Avatar
Which is the entire point of the ventectomy.. So you don't have to press that stupid button anymore, lol.
Bill
LNXGUY is offline   Reply With Quote
Old August 28th, 2015, 07:01   #6
osesu96
Fuel Economy: 50.2 / 45.8 / 43.2
Follow GWillie's process. It takes 10 minutes and is quite easy to do. Works a lot better when done.
2004 Jetta TDI GLS 5spd, RC2, Ventectomy, Phatbox, .681 5th , 'WD Collar Mod', VNT-17, 148k miles
2006.5 Jetta TDI "Diesel Edition" 125k miles
osesu96 is offline   Reply With Quote
Old August 28th, 2015, 08:41   #7
belome
Oh I know, but it isn't like it is a difficult task.
Old August 28th, 2015, 08:57   #8
LNXGUY
LNXGUY's Avatar
Of course not, but one less thing you need to worry about when it's -20 outside
Bill
Old September 2nd, 2015, 10:49   #9
lxrubin
Fuel Economy: 46 mpg
What's the purpose of this mod?
lxrubin is offline   Reply With Quote
Old September 2nd, 2015, 10:50   #10
belome
You gain about 2 gallons of fuel capacity.
Old September 2nd, 2015, 11:01   #11
I did this to my son's new (to him) Jetta a couple weeks ago. Forgot how to do it, it had been so long, but gwilli's pictures jogged my memory. Took about 5 minutes.
It's a great mod, makes filling the tank easier. After a while you can notice when the tone of the whistle of the air coming from the vent changes and it's time to slow the pump flow down to top up. Tank after tank of 700+ miles makes it worthwhile.
2002 Jetta wagon, 393K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 61K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old September 2nd, 2015, 11:29   #12
laxman21
Fuel Economy: 36.5
Meh, I tried this and could get the damn thing out. So, I just used some pliers and bent the plastic surrounding the button so it would hold it open. Would have saved me a hour of my time.
As a side note, I left my cap off yesterday and started the engine up and it drained the filler neck down to were I couldn't see diesel any more. Wounder how much more I could have got in there. Will have to experiment next time.
laxman21 is offline   Reply With Quote
Old September 2nd, 2015, 13:01   #13
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
Have you ever had the displeasure of being on a motorcycle mid curve and hitting a patch of spilled diesel fuel? It's like being on ice, so please always remember to put your cap back on...
Old September 2nd, 2015, 19:59   #14
deejaaa
deejaaa's Avatar
because you didn't do it right. use google for instructions.
Old September 3rd, 2015, 01:32   #15
UhOh
UhOh's Avatar
Recently did this on both my cars. Hardest part for me was figuring how to get the black plastic collar out! I was afraid of breaking something (plastic door and hinge), but finally just decided to push/compress it some and then swing it out- wasn't aware that door and hinge came out with the collar. After that it was pretty easy. Remember to line up the neutered plug properly so that it pops back in fully; note the orientation of the straight edge on the valve body.
First full tanks on my cars I got 729 miles and 746 miles. Had been getting about 100 miles less before. Clearly I'm getting 2 gallons more in these things.
For filling technique I just go by pump shut-off, as I'm not going to train my wife on the finer points of fully topping off (and risking spillage). I run the pump full throttle until it shuts off and then I run it again at 1/2 throttle. I fill up at the same truck stop and pump (most of the time) in which case I can expect to be fairly consistent such that my mileage calcs are pretty accurate.
ventectomy pics??? jswol TDI 101 6 February 8th, 2011 21:05
2005 Beetle ventectomy... pics Lightflyer1 VW MKIV-A4 TDIs (VE and PD) 0 January 25th, 2011 19:43
Ventectomy pics scottie_boy99 Fuels & Lubricants 1 March 18th, 2010 23:35
Ventectomy Pics- where? detoxed VW MKIV-A4 TDIs (VE and PD) 2 August 26th, 2005 16:45
Suspension swap meet - PICS, PICS, PICS!!! tongsli Eastern USA 52 May 17th, 2002 17:34
Page generated in 0.15609 seconds with 11 queries
[Output: 128.86 Kb. compressed to 107.36 Kb. by saving 21.50 Kb. (16.69%)]
