42meter
I need some knowledge please on my screen shot. This is for my VW 2012 TDI Passat. It has 2 coolant sensors, I have replaced the front sensor that is making the code. My question is, when I am looking at the reading, the -40 read out on number 2 ECT sensor, is that normal, or should it be reading the current temperature?
I have tested the wires going to the front temp sensor and I am getting 5 volts from the one side. I have done a continuity test also, but I am not getting anything from the meter on the other side of the plug. Is this normal for a VW? or could the wire on the one side possibly have a break in it somewhere? Please advise. Thanks!
Friday,24,April,2015,10:07:02:34575
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
Address 01: Engine (03L 906 012 )
10:06:54
082 Coolant temp at radiator output; unconditioned voltage 4999.8 mV
083 Coolant temperature 65 °C
084 Coolant temperature at radiator outlet; actual value -40.0 °C
085 Coolant temperature at radiator output; specified value 95.0 °C
086 Coolant temperatures ECT 1:65 °C / ECT 2:-40 °C
Wednesday,08,April,2015,16:53:02:34575
www.Ross-Tech.com
Address 01: Engine Labels: 03L-906-012-CKR.clb
Control Module Part Number: 03L 906 012 HW: 03L 907 309 S
Component and/or Version: R4 2,0L EDC H21 2157
Software Coding: 00190012042400000000
Work Shop Code: WSC 09003 957 00200
ASAM Dataset: EV_ECM20TDI01103L906012 004009 (VW41)
ROD: EV_ECM20TDI01103L906012.rod
VCID: 61C2421170CEA529011-8034
1 Fault Found:
8467 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2183 00 [237] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 70168 km
Date: 2037.14.20
Time: 09:08:47
www.Ross-Tech.com
10:06:54
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 70168 km
Date: 2037.14.20
Time: 09:08:47
