digdug
I opened it then went to close it and it just opens itself again even when the knob is in the closed position..
anyone else ever have this problem? thanks.
Be very careful to check for obstructions before doing this. When the sunroof is closed this way the pinch protection is not enabled.dr.diesle said:have you tried closeing the roof by using the key in the door lock front door and hold key till roof and windows close unless manual windows duh...worked for me it almost resets every thing ...
digdug,digdug said:I opened it then went to close it and it just opens itself again even when the knob is in the closed position..
In order to inspect the tracks you need to remove the glass. The sunroof must be in the vent position to remove glass. Take off the bellows covers. There are 3x T25 Bolts per left & right side. Once you remove all 6x T25 Bolts, glass can be lifted out & safely stored while examining the rails. Here’s a YouTube video that shows how to remove the glass.Re: 2003 Jetta TDI Wagon with sunroof that will not close.
Sadly and madly (like makes me crazy) none of the revelatory and helpful tips solve my problem. Though, using the "Rocker-Like" method with the switch in "closed" position I was able to get the passenger side sunroof to close completely the driver side remains open about an inch. I arrived at the "Rocker" method last after trying the physical "key" (not the fob) in the door handle, which just made the same grinding attempt at closing but would not close. And the manual Allen Wrench winding which sounded bad as it attempted to close but would not.
So, I am stuck. The sunroof will not close all the way or open at all, so now that i am convinced the trouble is a track obstruction I cannot inspect the track and i also cannot (seemingly) easily remove the window itself. Any thoughts?
