B.L.T
From pass to drivers side
425, 420, 430, 430 on a fairly cold engine. From my understanding and results from searching, this is in the norm of what it should be.
However, i still have a cold start issue, well more so a hard start after sitting for 4 or so hours.
Fuel tee filter replaced. All spring clamps have been replaced with hose clamps. Battery is oem replacement from about 3 months ago. Fuel hose's between injectors and back to injection pump are new. Timing is in the middle of the upper part of the graph(as per last time checked..couple months ago). Very little bubbles going through the line while running. However, i noticed when i shut down the engine, some bubbles come from the injection pump back into the clear fuel line. From my understanding, this can be from the seals in the pump and possibly the oring on the shutoff valve for the fuel? Other then this, im stumped. Im getting my vagcom next week so ill be able to produce more details then. But as of now, im out of ideas. Thanks in advance
