BeaverTDI
See photos on craigslist add here:
https://portland.craigslist.org/wsc/cto/d/rare-1996-vw-passat-tdi/6466211184.html
I've owned the car for 8 years and have most of the maintenance records from the previous family that owned it. It is mechanically sound and still has lots of power. Routinely gets 42-45mpg (48mpg on trips). I've owned several TDI's and this one has the best engine and smoothest transmission of any that I've driven. More Info about the car is listed below:
1996 B4S Passat TDI (90HP Turbo Diesel-1st US TDI release)
Made at Audi Plant in Emden, Germany
Blue Pearl Exterior / Beige Interior
5spd Getrag Manual
18.5 Gal tank, (700-800miles/tank)
293,000mi
Clean Title
Good Tires
Factory Radio / 6 Disc CD Changer in trunk
Maintenance/Upgrades (Over $2500)
Added Remote Start / Keyless Entry
Replaced Shocks / Struts with Monroe OE
New Passenger CV Axle
Replaced all engine / drivetrain fluids with Amsoil Synthetics
Synthetic Air Filter
New N75 Valve
New Headliner (common issue on these vehicles)
New Door Handles (common issue on these vehicles-front passenger still needs adjustment)
Replaced Drivers Side Window regulator.
Refurbished Headlights
Replaced Marker Lights.
Added fog lights upgraded switch
Replaced rear brake calipers/pads. New wheel bearings & synthetic Brake Fluid.
Extensive Belt/Seal Upgrades with German OE Parts Including: (TB Due for replacement at 300k)
Timing Belt (Long Life PTFE Coated Version) - OEM
67mm OD 'Lintens' Timing Belt Tensioner Idler - OEM
28mm OD 'INA' Timing Belt Tensioner Idler - OEM
8mm Securing Bolt for 28mm OD Timing Belt Tensioner Idler
Self Locking Nut w/ Lock Washer for 67mm OD Timing Belt Tensioner Idler
Multi Sized Stud for 67mm OD Adjustable Timing Belt Tensioner Idler
Mounting Bolt for 28mm OD Timing Belt Tensioner Idler
Water Pump w/ Gasket O-Ring
Thermostat w/ O-Ring Seal
Viton Front Crankshaft Seal
Viton Camshaft Seal
Viton Intermediate Shaft Seal
Viton Fuel lines
Intermediate Shaft Seal O-Ring
Improved Allen Bolts (Grade 10) For Lower Crankshaft Pulley
Valve Cover Gasket
Valve Cover Mounting Bolt Seals
Power Steering Drive Belt
Alternator Serpentine Belt
AC Serpentine Belt
Includes some spare parts including plastic trim pieces, front wheel bearings, front brakes, Pentafrost antifreeze, etc.
I've invested a lot of time and money into this car and it has been very reliable. The engine and drivetrain are in very good shape and should last for many more years. The body does show some signs of wear for a car of it's age, but is still in relatively good shape. I'd feel comfortable driving this car anywhere in the country.
I now own an Electric Vehicle and work close to home so I don't drive this much anymore. I want this car to go to a TDI enthusiast who will give it a good home. Will only sell to a local buyer or person willing to travel here for sale with cash/cashiers check. No shipping. Please email, call, or text with any questions or to schedule a test drive.
5spd Getrag Manual
293,000mi
Clean Title
Good Tires
New N75 Valve
Viton Camshaft Seal
Viton Fuel lines
Valve Cover Gasket
AC Serpentine Belt
