I have just been reading a few threads regarding cam choices for 8v PD 1.9 engines, and it appears to be a well known fact that the TDI intake ports are very restrictive mostly due to cam lift and duration, but my educated guess is its also partly due to the restrictive helical/snail shape nature of the intake ports, this is what generates the swirl effect inside the comustion chamber.
my question is, has anyone conducted any type of swirl measurements on a flow bench using a swirl meter like this:
http://www.performancetrends.com/swirl.htm
It seems that the 1.9 8v engines respond well to cam changes with more lift and duration, I think one of the side benefits of upgrading the cam, is less swirl.......but thats just an educated guess.
Also, has anyone got any flow-bench results from any standard or modified 1.9 PD 8v heads???.....someone mentioned the standard cams and heads are limited to about 240bhp, which is actually not too shabby to be honest.
