ABS pump bleeding question
RacerTodd
Kirkland, WA
2001 Golf TDI
I'm finishing up my ESP/ASR upgrade this weekend by installing the new ABS pump. This is my first time bleeding the ABS pump using VAG-COM.
My question is: how much brake fluid is used when doing the ABS pump bleeding? I don't want to find myself running low and having to make a part store run in the middle of the job.
RacerTodd
Kirkland, WA
2001 Golf TDI
jcrews said:
I bought 2 liters and I think I used 1.5 if not less.
Was that for just the ABS pump bleeding? Or was that for bleeding the ABS pump and the rest of the system as well?
2004STARWARSTDI
LAKELAND, FL
2004 Platinum Gray GLS Jetta / 2006 Silver Jetta with DSG
Brake flush
Has only taken 1 liter to do complete system.:D Also VW dealer uses only 1 liter.
