It's easy to make your own. I cut some 1-1 1/4" long strips of Al sheet metal about 3/8" wide(slot width). Credit card material might work also. Cut one end of each of the 4 strips at a 60 degree angle. Wedge each strip into the slots, pretty tight, with the long side facing the center of the radio and short side out. Grip the radio via the tape and cd slots and pull the radio out. A bit of wiggling of the parts may be necessary, but no heavy force. Put the tabs with your owners manual for the next time.
