td04hl-15t-5cm from a saab 2.3 HPTI would like to get away from the vnt15 because I drive it hard a lot of the time, I'm worried about snapping the shaft. I'm not too concerned about turbo lag, but I want to keep my engine fairly reliable. No ARP head studs, water injection, nothing crazy like that. I can upgrade the exhaust at some point if needed, but for now I'll be sticking to stock.
very very nice small turbo for these engines
dead reliable with no vane garbage to mess up, and no-boost breathing is freed up by a lot, making for better lugability for starting up from stops
best yet, they're about $50 from pick and pull
were I to do it again I'd get a passat manifold and make an adapter plate rather than fabricating a tubular manifold
bop the pump topcover around until the no fuel transition is smooth from overrun to powerStill trying to decipher how to set optimum IQ.
all you're setting with topcover position is where the transfer port closes in relation to the camplate lift
