HelenaTDI
- Joined
- May 27, 2007
- Location
- Helena, MT
- TDI
- 2003 Jetta GLS, 2002 Golf GLS, 2001 Jetta GLS, 2002 Golf GLS & Jetta GLS(Parts Store), 2015 Passat 6spd
Pulled a WOT on the interstate on ramp Monday. Heard a pop and then a huge white smoke cloud followed by limp mode. Immediately pulled over and shut it down and had it towed home.
No coolant loss head gasket appears to be fine
Approximately 1.5qts low on oil.
Lower intercooler full of oil.
Verified VNT rod adjustment. ~3 inHg of vacuum when rod started to move. 18 inHg at the stop.
Basically confirmed time to pull the turbo.
Pulled the turbo today and found the turbine shaft broken. Exhaust turbine was missing. Apparently my 2.5" straight exhaust ate it and puked it out the exhaust pipe.
Only had maybe 9,000 miles on the new turbo when it grenaded.
List of mods on my 02 Golf 5spd.. VNT17 RIP 9-5-16, PP764's, 3bar, PD150 intake w/race pipe, straight 2.5" exhaust, Kerma tuned, NSP egt and boost gauges, etc.
Plan on thoroughly cleaning the IC and associated pipes. Anything else I should look at? Plan on monitoring Group 11 when I'm back up and running again. Must have over boosted when the turbo went? Not really sure what to make out of why it happened. Anyone else have a similar experience?
