evolveVW
Long story short- hit a bump in the road (at night, didnt see how big it was) that broke the block where the passenger side engine mount bracket bolts to it. Also sheared off the bolt just in front of the timing belt tensioner. Car ran for about ten seconds and died. Would not start again. The engine had moved forward, and the bracket contacted the tensioner pulley enough to drag on it a bit. Got the car home and managed to get it to at least start, run poorly for less than ten seconds, and died. The car was belching white fuel smoke from the exhaust. So at this point it think retarded IP timing or bent valves. As an interesting side note, a Hyundai hit the same bump, and shredded its tranny just before I hit the bump. Gears on the ground, the whole nine.
Fast forward. Tear everything apart to fix the mount issues (thank you dieselgeek!) Reset static timing, the crank was off about a tooth. Put everything back together, still the same issue.
Background info
No codes in VAG-Com
Fuel shut off solenoid just replaced.
Timing belt done less than 5K ago.
Has RC3 and Sprint520s.
Glow plugs, harness, and relay all have been replaced since I have owned the car.
I havent poured through the no start thread again yet, but would appreciate any specific insight. TIA. Havent done a compression test yet, seemed ok when rotating it by hand, but who knows.
Background info
No codes in VAG-Com
