guillaumeber
I've got a concern since a couple months.
My scanguage2 has been displaying me, for about 4-5 years, that my engine was running between 86 C and 88 C, even in hot summer. This seemed normal to me.
Since a couple months, started at the end of the winter, it can be sometimes at about 88 but most of the time, I get a steady 92-93 C which seems a bit hot to me, however, it seems steady there and never went over 93 C.
What would be the best diagnostics? My coolant temperature sensor could be faulty or my thermostat, or my radiator getting clogged....anything else?
I could try reading the resistance on my coolant T sensor but where can I get the specs I should get?
Other tests I should make?
would you consider 93C too hot too?
thanks !
g.b.
thanks !
g.b.
