PHOTOGUY1000
1998 Volkswagen Jetta TDI
Purchased from Leonard at Wild Rose in 2012 West Coast Car No Rust
194K 40-50mpg
Timing Belt at 167K by Wild Rose
Garaged
Paint 2012
Wheels & Tires 2013
Shocks Struts 2013
AC Comp 2012
Brake Pads 2014
Battery 2015
Alternator Rebuild & Clutched Alternator Pulley + Serpentine Belt Tensioner Roller
PCV/CCV Valve
CCV Breather Tube
CV Boot Left Inner
Manual Transmission Fluid
Metalnerd Magnetic Oil Drain Plug & Washers
Coolant Flange for Cylinder Head
INTERCOOLER TURBO HOSE
New Glove Box
New Driver Seat Cushion
New Heater Core, Evaporator Core, Vent Foam Replaced
Leather shift & Break boots
New Valve Cover Gasket
New Oil Cooler O-ring
Headliner & Sunroof replaced in 2012 Interior is Beautiful
Alpine iDA-X305S CD/MP3 In Dash Receiver
New Style Key FOB
Needs... A/C needs Charge have not done it since I replaced core also sunshade needs to be recovered I have material just have not got to it yet. Cluster has been rebuilt but it still has sporadic tachometer & Speedo... Car has Scangauge II so not really a big problem.
Car is ready to drive & enjoy you will not find a nicer example of this body style $4500
I will add more photos & details over the next couple days.
194K 40-50mpg
Garaged
Paint 2012
Wheels & Tires 2013
Shocks Struts 2013
AC Comp 2012
Brake Pads 2014
Battery 2015
PCV/CCV Valve
CCV Breather Tube
CV Boot Left Inner
New Glove Box
New Style Key FOB
