EECSentric
[SOLD]: 2003 Jetta Wagon TDI 5-speed, 196K mi, Boston
SOLD.
It was and is a great car. It will be missed but has a great new owner.
Hi Folks,
Update. No longer a feeler but actually for sale. Family member that I thought wanted the car didn't want to learn stick. Looking for $xxxx to a good TDI loving home. I'd like if possible to sell the car before I need to put the snow tires back on.
I drive the car every once in a while but not too often. I keep it on a battery maintainer otherwise to keep the new battery healthy.
The Car: 2003 Jetta Wagon GL TDI w/ 5 Speed & Monsoon audio package. It is the last of the ALH series and the Wagons, as you know, were originally assembled in Germany. It has 196341 miles on it currently. I am the second owner and purchased the car in 2004 with 44K miles on it from the dealer as a CPO. I've kept the car very clean (as you can hopefully see from the photos).
Maintenance The car has seen full synthetic 5W-40 it's whole life on schedule. Anything more than basic maintenance has been performed by a trusted mechanic (KMH for the past many years). Most recently replaced the EGR flex pipe. Full timing belt kit & water pump were done by KMH at 176K after the water pump developed a slow leak. Brakes & Pads were done at 156K miles and A/C compressor and alternator one-way pulley shortly after.
Update 9/15: Replaced the battery with new OEM unit
Modifications
What's needed Very little. No mechanical problems and no internal damage, just a few more superficial issues. I tried to capture the cosmetic ones in the photos.
Photos in the next post
SOLD.
Hi Folks,
Modifications
- Rocket Chip Stage II (2006)
- Bosio DLC1019 nozzles (w/ pop testing & balancing by KermaTDI, 2014)
- VR6/G60 Clutch Upgrade (2006)
- Bilstein TC Shocks & Struts (Installed at 170K miles, 2014)
- Audi TT solid rubber control arm bushings (2014)
- Billet machined CCV filter (and oil cap just for fun, 2005)
- E-code headlights (volxtuning, 2014)
- Euro light Switch w/ 5-light brake mods (2004)
- Frostheater (1kW coolant heater) with marinco plug (2004)
- Blitzsafe audio adapter w/ Belkin bluetooth unit for connection to stock Monsoon headunit
- OEM rubber floor mats
- Custom LED strip light for trunk (very bright)
- Audi Q5 rear wiper & sprayer (2015)
- Rear Red TDI badge
- BF Goodrich Advantage T/A on 15" OEM steel rims w/ hubcaps (lost the logos driving a while back)
- Blizzak MZ-01 on 16" steel rims
- BF Goodrich g-Force T/A on 17" alloy rims from a Dodge SRT-4 (the rubber is old enough that it should likely be replaced). These bolt up with the same hub bore, just need conical bolts.
- There are some minor paint chips that have developed into a few small rust spots (see photos)
- The driver side fender is starting to see some rust (KMH replaced the pass side last year) and there is a kiss mark from the widowmaker jack
- Update 9/15: Fixed tailgate actuator connection
- The plastic end pieces to the trunk cover failed and I haven't repaired it yet.
- I bought the relay & wiring harness for the E-code fog lights, but I haven't installed it yet so it's just in a box
