TDIfor
Gentlefolk;
'02 NB TDI 5Sp 178K miles
When I turned off the engine today after coming home from work, in 90+ degree weather, with A/C on, the engine cooling fans continued to run on high. I finally had to disconnect the negative battery cable.
This happened before, and eventually it stopped... it only hiccupped like this a couple of times.
In trying to track down A/C issues a year ago or so, I swapped out the fan control module, so there is a newer FMC in there.
If the FMC is sound, is there another relay there that could be flaking in the high temps?
Thx!
Don
Thx!
Don
