vegipwrgirl
2002 Volkswagen Jetta Sportswagon
110hp ALH TDI MK4 * 182,000 miles
5spd Manual Transmission
$3400 OBO
Recent/past maintenance:
- BRAND NEW REAR BRAKE PADS & ROTORS
-TIMING BELT REPLACED AT 130K
- NEW TIRES NOV '15 & JAN '16
- AC COMPRESSOR REPLACED
- NEW RADIATOR
- LARGE COOLING FAN REPLACED
- NEW STARTER
- NEW BELT TENSIONER
- AIR, OIL & FUEL FILTER REPLACED AT 130k
- NEW SPEED SENSOR
- Getting glow plugs replaced this weekend (Dec.1)
BASIC info:
- TANK CAPACITY 14.5GAL , 40+MPG
- LEATHER Heated SEATS, SUNROOF, AUTOMATIC WINDOWS
- CD & CASSETTE (RADIO NEEDS FIXED, HAVE KEYS)
- NON-SMOKING VEHICLE
- SOME INTERIOR STAINS & MINOR EXTERIOR RUST
- NO DENTS
- Battery is good
- LEFT SIDEVIEW MIRROR CASE WAS REPLACED AND IS SLIGHTLY DIFFERENT COLOR
Maintenance needed:
The speedometer drive gear needs replaced. Because this is broken it does not send messages to the instrument cluster so the speedometer, odometer, cruise control and fuel gauge are not functioning until it is fixed. Sometimes 4th gear gets jammed, but if you get the RPM high enough it will shift. This only happens once a month or so. Check engine light has codes referring to instrument cluster: P1163 AND P1650
Driver side and passenger rear side floor accumulate moisture sometimes...not sure why.
Other Notes:
* Transmission has a small hole that was patched by my trustworthy VW guy. It's above the fluid line so very low risk.
* Originally a 1.8t gasoline model. Re-done with original drivetrain from Netherlands. I purchased after the swap in 2013.
From the previous seller: The only engine part that is different since it is a european model is the valve cover gasket. It uses the gasket from an AHU or 1Z engine that is found in the 1996-1998 Passat / Jetta TDI. The part is http://www.idparts.com/catalog/product_info.php?products_id=251 It is fine now, but some time down the road, if it does need replacement, at least you will know. The part is just as easy to find, and better since the 2000-2003 valve cover gasket is integrated into the valve cover and runs over $100 for the assembly.
*DOES NOT HAVE GLOW PLUG LIGHT *
$3400 OBO
- NEW RADIATOR
- NEW STARTER
- NEW SPEED SENSOR
BASIC info:
- NO DENTS
- Battery is good
Maintenance needed:
Other Notes:
